Question about JVC AV-36950 TV
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
I have a JVC AV-36260 that suddenly stopped working. I turned it on one morning, heard the usual initial click and the TV was blank with no sound and the standby light started continuously blinking. I unplugged the TV and let it sit a few hours, then tried plugging it back in and it worked fine. This continued for a few days until eventually it would not turn on at all. I was thinking maybe it was a cold solder joint. Any ideas?
    Problem Solver:
  • 8 Answers
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Posted on May 25, 2010
    Top Expert:
  • JVC Master
  • 74,887 Answers
Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 30, 2015
    New Friend:
Your crt is dead i think
JVC AV-F29MX3 I was watching a film on my DVD connected to the TV, when suddenly the screen turns black with no sound heard. Also the front light indicating 'ON TIMER' and 'ECO' started blinking in red...
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective .................. so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective.......... price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore ( 09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact jvc service centre.........
Apr 21, 2011 | JVC AV-F29MX3U 29" TV
The on light is blinking but there is no picture or sound.
I have the same problem with my JVC AV27750, the problem is probably the power supply relay circuit, just check and replace the 1000uf capacitor
Jul 06, 2009 | JVC AV-36260 TV
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
No picture, clicking sound coming from speakers, power light blinks
visit http://fletchersite.com/documents/ask.html for an immediate solution to this problem.
Jun 30, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Jvc av36260
check the horizontal out and the flyback, if its good check the vertical out. if it does it again the crt has a leakage or busted.
Jan 23, 2008 | JVC AV-36260 TV
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Jvc 48" tv model av-48wp34
Sounds like you lost the High Voltage. The beating sound is the power supply trying to start up. After a predetermined time it will quit to protect the set. This is a very common problem and typically not that much to repair. If you are not an electronics repair technician you should find a reputable repair shop and enlist their services. I would not think the cost should exceed $150.00 to repair. Good luck.
Jun 18, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-36950 TV Logo
505 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
