Question about Panasonic PT-44LCX65 Television
Were is the air filter?
PT-44LCX65
  • liss2224 Jan 08, 2009
    i need to clean the air filter but i lost my manual. where is it?
The air filter is in front of the tv pop off the front and it is in a screwed panel you can take it off but i vac it out and air dust it out and it works great u need to not smoke around the tv or burn candles around it hope it helps
Posted on Jan 30, 2009
Pt-44lcx65
That seems it might be an issue with your ballast. With time this could cause the picture to go away, discountdashmerchantdotcom
Jul 26, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
My panasonic pt-44lcx65
The fix for the air filter problem also you are probably getting the on screen message clogged filter also. It can be repaired by relacing the light engine (VERY EXPENSIVE) or remove the light engine and clean the filter much less cost infact none if you know how.
To clean the filter you must remove light engine and you will see at the top a black housing with two screws that must be removed to remove light engine.
A service maual on how to remove light engine is very helpful wich can be ordered on the internet. Any way you want to remove 4 screws from the housing you will then see the filter and 4 more screws to remove in all four corners, remove the screws and then pry the rectangular filter out of the assembly. This may take some effert so be careful. Look at filter through light it will probably be dirty wash with water and blow it out with comprssed air look at it through to insure it is clean then reinstall .Reassemble and you should be good to go.
Jan 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic
The air filter should be a user-accessible thing. Consult your owners manual for details. Can you find the manual?
Dec 30, 2008 | Panasonic PT-44LCX65 Television
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
PT-44LCX65 Convergence
Look in the service manual for the section on using the adjustment set-screws. (I'm not an expert, but this sounds like what you are looking for.) This section is somewhat toward the back of the manual before the electrical schematics and part explosion pages.
Jun 03, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-44LCX65 Projection TV
There is a filter in the front of the machine, right beside the lamp door theres another one. blow that out with can air will kill the error for a while then you might needs to get it serviced because one of the fans is caked with dirt and if you dont know electronics i would not try to take it apart to clean it.
Mar 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-44LCX65 Television Logo
668 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
