Question about LG 42LC2D 42 in. LCD HDTV
Lg Plasma Display settings keep switching
I just bought a LG 42PL20 plasma tv. Everything works fine accept every time I manually adjust the display settings to my liking, the tv switches back to the default "vivid" setting after what seems to be 5-15 minutes. Please help.
When you boot up your tv for the first time, you get to choose between home and shop-mode.
In your case, he TV is set to "shop-mode".
Then it will go back to factory settings after 5-10 minutes. (so that customers won't mess up the settings all the time)
So change the settings from shop to home, and your problem is fixed!
Posted on Mar 01, 2009
  • 108 Answers
You have an issue with the main board.
Posted on Jan 08, 2009
Kindly help me with my plasma tv LG PK760-ZC no picture no sound?
Repair work to Plasma TVs are skilled one. It will be best to contact any service technician in this case.
It sounds that the main power regulator board to your Plasma display is faulty.
Eventhough you are able to buy and replace a power regulator bord to this set, there are some voltage adjustments have to be done; and it is a must. you should have all testing instruments, and ability to follow its circuit diagram, and have to find out the voltages set adjuster points.
If you are confident, just proceed. Otherwise, contact either a service technician, or the authorized service center for LG
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 25, 2014 | LG Televison & Video
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
How do I colourwash my LG Plasma TV model LG 42PC55
In the menu selection you should have something in the options called ISM Method. Set this to "color was" to wash colors out, then use the white wash to get the ghost out. It is also recommended that you use your plasma at 50% contrast as the gas used to display color needs time be evenly worn down. I have a brand new 50" LG 1080p full HD 600Hrz that I bought last month, and I already have burn in because I didn't read the manual. Make sure you're using the orbital setting during the first 200 hours as well this will reduce the intensity of the burn.
Feb 20, 2010 | LG 42PC5D Television
Broken screen(S)
The Plasma Display Screen for 42PC3D is listed below.
LG 42PC3D Plasma Display Panel Replacement
Apr 13, 2008 | LG 42PC3D 42 in. Plasma Television
Ted scaning elektronik tv service
I have a TWP4205[samsung display s42sd-yd05] end VMB 1110 tuner box for TWP4210[LG panel]Hou switched in service mode,for geometry settings...please!
Feb 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
White line
There are individual drivers for each line of plasma cells in the display (horz. & vert.), but they usually are an integral part of the display module that can only be repaired by the manufacturer. A new 42" HD-ready set with more features can be bought for 50-75% of what was likely paid for this one. The cheapest thing to do is learn to live with it. (That's what I'd do until the set got worse or the prices got even lower.)
Apr 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Lg 50px4d
LG 42" Plasma TV 42PX3DCV Parts - YSUS ZSUS CTRL Part Number (set): 6871VSNB03E Part Numbers (individual): 6871QYH036D, 6871QZH041B, 6871QCH053G Part Number: 6871QYH036D Description: PCB ASSEMBLY, DISPLAY YSUS ASSY 42V7 FOUND THESE ON THIS: http://cgi.ebay.com/LG-42-Plasma-TV-42PX3DCV-Parts-YSUS-ZSUS-CTRL_W0QQitemZ110086231102QQihZ001QQcategoryZ116199QQcmdZViewItem HOPE IT HELPS
Feb 26, 2007 | LG 50PX4DR 50 in. Plasma TV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 42LC2D 42 in. LCD HDTV Logo
554 people viewed this question
Computer Repairing
Computer Repairing
