Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
HEATING ELEMENT IS RURNED OUT
The heating element is burned out. Can I order a new element or is it beyond repair? Does a the warranty cover this?
    Genius:
  • 1,689 Answers
You can order a new heating element from the manufacture. But, the crimp connectors and the thermo-fuse may also have to be replaced. You will need the crimp tool for the crimp connectors. You will also need a meter to verify the connections.
If you take the unit to an appliance center they can service it for you. But, you may find the cost of the parts alone to not be feasible.
Jerry G.
Posted on Jan 10, 2009
I have a Tim Horton's Bunn coffeemaker. The coffee is not hot enough..both the water and element are both hot, but , obviously, not hot enough. I cleaned it 2 weeks ago and now this is happening. Which part is not hot enough?
Posted on Jan 24, 2009
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Model 790.96009601 I replaced the heating element that burned out. New heating element does not work.
The replacement heating element could be defective, not burned out. Also, the replacement element could have been installed incorrectly.
Oct 29, 2014 | Kitchen Ranges
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Ge medallion 850 new elements and thermostats still not heating up
see this possible causes:
1) You must shure the heating element show continuity see the video>
2) Test for continuity the thermosta see the video how to do it
3)TEST THE thermal fuse, for open and replace.
4) Test any WIRES for loose, or broken or burn and repair.
5) If anything is o.k see the diagram. You must test the contact from the a) Timer for open, or dirty, or wires loose, broken or burn b) Test the selector temperatur for defective in order to get the heating element to work, and replace if necessary. God bless you
Jun 09, 2012 | Dryers
Dryer will not heat up
Hello there and welcome to fixya
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out,
Oct 24, 2011 | Dryers
Maytag gas dryer flame comes on but will not stay on
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
We had ours replaced several years ago by a reasonably priced repairman. It bought us another 8 hears on our dryer!
Jul 27, 2011 | Dryers
Gas dryer kenmore elite runs but won't heat
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
My gas dryer is working but there is no heat so my clothes will not dry. I've got all these wet clothes and I need to get this dryer to heat up. Please heat!
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
743 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
