Question about Canon MX700 Office All-In-One InkJet Printer
Can I bypass an ink tank not being recognized?
I use this printer to print pictures to put on cakes, so the "ink" is actually food coloring and the "paper" is actually a sheet of "edible" paper, but when I put in the tank - with the chip- the printer is saying the tank is not recognized. I do refill the tanks. Do the chips just eventually wear out and is this just a matter of getting a new chip?
    Scholar:
  • 65 Answers
Hi
Actually no you cannot, you would end up damaging the printer.
Best Regards
Posted on Jan 07, 2009
Lexmark Pro 705 won't let me print after refilled
If you refill the regular lexmark 100 ink cartridges, you will not be able to use it because there is a rfid chip that track the ink usage. you will need to buy the 100a type which will let you print if the ink level is empty. since you have refill the 100 ink cartridge, you can swap the 100a chip to your 100 cartridge.
Apr 19, 2010 | Lexmark X4650 InkJet Printer
Canon MP140 fails to print
I don't think that has anything to do with reaching the board of 5000 copies. Your cartridges have no chips on them or anything. You might actually have a problem with your black ink cartridge, as the printer is telling you. Remove the black cartridge, gently wipe the contacts with a dry cloth and put it back in. Hold the "resume" button (triangle in circle) for about 10 seconds to try and reset your cartridge. If none of that works, I suggest you buy a new black ink cartridge.
Apr 07, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
My Canon Pixma MP160 printer is showing a error 5 code after i just installed a new canon color ink cartridge number 41 how do i bypass the color ink or fix it?
try to remove the cartridge from the printer and then try to print some docx,,, without the cartridge.... an error should say that the installed cartridge is not recognized... just try to print thrice or more then put back the cartridge... this should solve the problem.... thnx..
Mar 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
After cleaning print heads,which were causing poor print quality,i get an error message ...ink cartridges cannot be recognized. i am using after market cartridges,but have used them before with no issues....
Head cleaning procedure consumes a lot of ink. Ink level counter run too. So, after some head cleaning ink level counter reach zero level (ink out/empty level). Ink tank can not use again even there are ink at tank actually, because chip reach zero level. Reset chip using hardware resetter and you can refill ink tank.
Oct 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Mp530 edible ink
You need to clean the print head manually. Remove tanks from print head, then remove print head. Find a small tray you can put hot water in to the depth of a quarter inch / 6 mm. Soak bottom of print head. Do not touch or get wet the electrical contacts. Next while holding print head in left hand carefully pour a small amount of hot water in the each ink tank well in the print head. Now dab the bottom of the print head where the jets are with a paper towel. Keep dabbing till you get equal size spots of all the colours. Best to wear plastic gloves doing this. Best to use battery water (de-ionized) but if you don't get scale in your electric jug your tap water is fine.
Sep 18, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
Ink cartridge problem
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
177 people viewed this question
old marine
old marine
