Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I deleted files from my computer and would like to delete them from Maxtor as well but they are still on Maxtor backup. I am unable to delete them. Not all the files show up when I click on the Maxtor drive so I can't access the Maxtor files that I want to delete.
Beni S-P
  • 1006 Answers
SOURCE: Maxtor 3200 access
yess sir
Posted on Oct 28, 2007
SOURCE: Maxtor 3200 backup drive not recognized in my computer to access
Posted on Dec 31, 2008
  • 14 Answers
SOURCE: Maxtor won't allow me to delete files that are no longer on my XP
You might not be able to see the hidden files... If this is the case you can enable XP in order to view them as follows.....
Windows XP and Windows 2003
To enable the viewing of Hidden files follow these steps:
  1. Close all programs so that you are at your desktop.
  2. Double-click on the My Computer icon.
  3. Select the Tools menu and click Folder Options.
  4. After the new window appears select the View tab.
  5. Put a checkmark in the checkbox labeled Display the contents of system folders.
  6. Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
  7. Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
  8. Remove the checkmark from the checkbox labeled Hide protected operating system files.
  9. Press the Apply button and then the OK button and shutdown My Computer.
  10. Now your computer is configured to show all hidden files.
Posted on Jan 08, 2009
  • 6 Answers
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Posted on Feb 14, 2009
  • 739 Answers
SOURCE: Cannot delete files from Maxtor Hard Drive on Mac
Hi Simon Is there a problem deleting or is it that you just don't know how to do it?
If it's the former you need to supply a bit more info. If it's the latter then it's very easy.
Highlight the file you want to delete, right-click and select move to trash (second item down).
This moves the file to the trash but doesn't delete it.
Next you can right-click on the trash icon in the dock and choose Empty trash or go to the finder menu and select empty trash from there. After that your files should have been deleted from the maxtor.
Simple eh?
Posted on Aug 13, 2009
Tried to run a full system backup with FreeAgent Go. Backup failed and it looks like some files and programs were deleted from my computer in the process.
Unless you asked the backup program to delete files it won't. The program may have deleted some files it created for its own use.
What error code did it give for failing the back up. How do you know you need the deleted files?
Mar 17, 2014 | Computers & Internet
Does my Maxtor back up my iphotos?
Run a time machine backup. Then the easiest way would be to find a photo that you are willing to delete in iPhoto.
Jot down the name of the photo file, delete it. Then empty the trash.
Then go into time machine, try to search for that file, when you locate it, restore it. If you can then there is probably a good chance that you time machine backup is good.
To be on the safe side why not create a manual backup.
You'll find the iPhoto Library at:
/Users/username/Pictures
"username" will be your name that appears when you login to the computer.
  1. To get there, double-click the icon for your hard drive to open it, then double-click the Users folder. Double-click your Home folder, which is identified by a house icon and your username, and then double-click the Pictures folder to open it.
        1. Inside the Pictures folder you'll see a file called iPhoto Library. Copy the iPhoto Library file to a location other than your hard drive, such as your Maxtor external hard drive.
Feb 12, 2014 | Apple MacBook Pro Laptop Computer with...
Unable to delete files in maxtor onetouch iii mini
Access can be denied for several reasons - if the file is in use or even part of it - try dragging the folder or file to your desk top and then delete it
May 07, 2010 | Maxtor OneTouch III Mini Edition 120GB...
I have a Maxtor One Touch II. I went to backup my computer and got an error massage; " Grooming backup set restore point failed; error 2242". I "looked into the system" and could not see any restore...
You indicated that ..."most of the drive's capacity is used."
That may be your problem. When you make a backup you need room for the software to create temporary files before completeing the backup. These temp files are deleted once the backup is complete. There's no real rule regarding the amount of extra space to have available, but I use 10% of the total size of the backup and have not had any problems. I'm also backing up to Maxtor One Touch II.
Jan 27, 2010 | Maxtor Hard Drive
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Simple eh?
Aug 13, 2009 | Maxtor Hard Drive
Onetouch 4 internal error 8211
That error occurs when the 3 Quickbooks files don't have the same date. I'm not sure how they get out of synch, but if you check the dates of the files on your Maxtor backup, you'll find they are different.
The easy solution is to delete the files from your Maxtor backup, and then immediately do another backup. Maxtor will copy the current files over and you'll be all set.
Oct 26, 2008 | Maxtor Hard Drive
Sep 16, 2008 | Maxtor Hard Drive
External hard drive
I'm not overly familiar with Vista yet, but I believe that you will have to delete these as administrator. Use the Vista help menu, you'll find it there. If it's a program file you will need to uninstall, versus delete, from the add/remove programs in the control panel.
Jun 24, 2008 | Acer Aspire 5100 Notebook
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
16 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
