Question about Proform 575 Crosstrainer Treadmill
E-21 After storage of 6 months, I plugged my treadmill in and without being started, it took off fast for 10 seconds and stopped and never started again. The power comes on but not the belt. It says E-21 on it.
Start /variable sp. sw. needs replacement.
easy fix for most electric appliance repair person
Posted on Jan 07, 2009
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Reset ecu on Nissan hardbody 2006 model.stoped it at home,now wont start.maybe for second or two.Nats light not working on dash. keys still opening doors,enjin turning,does not start.enjin check light
Give this a try.....Timing is not as critical with this method...no stop watch needed. Just count in your head...one-one thousand, two-one thounsand, etc, or usestop watch. The most critical step is step #3....wait 10 sec, instead of 7.
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then 81377951893%26mt_id%3D570%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F181377951893%26mid%3D446528%26sdc_id%3D%7Bsdc_id%7D&DealName=12v%20Electric%20Push%20To%20Start%20Engine%20Ignition%20Button%20With%20Red%20Led%20Light%20Up&MerchantID=446528&HasLink=yes&category=0&AR=-1&NG=1&GR=1&ND=1&PN=1&RR=-1&ST=&MN=msnFeed&FPT=SDCF&NDS=1&NMS=1&NDP=1&MRS=&PD=0&brnId=2455&lnkId=8070676&Issdt=150102050536&IsFtr=0&IsSmart=0&dlprc=19.99&SKU=181377951893">start engine. Done!
Jan 02, 2015 | Nissan Cars & Trucks
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
My treadmill runs for 15 minutes than stops for a minute than start up for 10 minutes than stops, than start up
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Jan 11, 2011 | RTO Image 15.0R Treadmill Walking Belt
Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Dec 30, 2009 | Exercise & Fitness
Robin engine for 27 ton log splitter..starting problems
remove the float bowl from the carburator and clean it out. Either the float is stuck of the needle valve is gummed up. Both the float and needle valve together regulate the fuel allowed into the bowl, if they dont allow fuel in or allow it in fast enough, the engine dies. Also check for a fuel Screen in the fuel tank, it may be plugged up.
Oct 01, 2009 | Garden
Proform 575 Crosstrainer Treadmill Logo
207 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Jon Schniers
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
