Question about Gateway MX7118 Notebook
Gateway mx7118 says drive has corrupt files cant repair using win
Says drive has corrupt files cant repair using windows xp
need to know how to change out the hard drive
  • sonnyx6 Jan 08, 2009
    i only have recovery disk
    and tried it a couple times didnt work
  • Gateway Master
  • 32,281 Answers
You don't need to change or buy another hard drive, unless you want to install a larger size hard drive.
Boot up with the Windows CD and reinstall Windows.
Posted on Jan 07, 2009
  • Chris Hingee
    Chris Hingee Jan 08, 2009
    To boot up from the CD you have to change the CD as the first boot device. Go into the BIOS to change it later you can change it bach to the hard drive as the first boot device.
    You need to do this even if you install a new hard drive.
Wont start windows xp
Repair Window Xp by inserting windows XP cd in CD drive. After repair use a system utility software like RegInOut to avoid this error in future. It will also fix corrupt registry files and windows files.
Dec 28, 2011 | E-Machines Computers & Internet
Tip
Corrupted file in win xp
<span>MOST EASY WAY to fix corrupted file in win xp<br /><br />This tutorial has been made so people that are having problems with corrupted files, can learn how to fix them easy.<br />Required:<br />1. Windows XP operating system<br />2. Windows XP cd<br />Now, follow this steps:<br />1. Place the xp cd in your cd/dvd drive<br />2. Go to start<br />3. run<br />4. type in 'sfc /scannow' (without the ')<br />Now it should all load, and fix all your corrupted file on win XP.</span>
on Apr 04, 2011 | Computers & Internet
I cant clean install or run win xp from c drive.or from cd rom using win.repair console ' specified drive is not valid/there is no disk in the drive'? when i type in fixboot in command prompt.. i have...
if the repair console cannot find the c:\ drive then yes the hard drive is done. Before you trash it though I suggest using an Ubuntu Linux Live CD to see if you can rescue your files.
Mar 14, 2011 | Evesham Computers & Internet
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
Need to reboot my crashed computer cant get windows xp to reboot
HI how are u, ur Windows Xp is corrupted
Cause :
1. Viruses
2. Computer was not Shutdown properly
3. Some windows File Corrupted
Solution>>>>>>>1.
1. Go to Safe Mode at starting mode press F8.
2. If Computer Go to safe mode successfully>>
3. Go to start >> Programs>> Accessories>>System tools>>System restore.
4. Restore ur computer in privious date.
Solution>>>>>>>2.
1. Insert WIn xp cd in cd rom and restart it.
2. Repair Your win Xp via a Repairing utility.
Solution>>>>>>3
1. VIa a formmating utility U can install a new fresh copy of windowxs.
Thanxs
Mukesh Kumar
Mukesh_ibm@yahoo.com
May 12, 2009 | Microsoft Windows XP Professional
HELP! Laptop will not boot up!
Try an XP repair:
Boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 10, 2009 | Gateway 3550GZ PC Notebook
Missing or corrupt win/sys32/config/ sys file
The best thing to do is borrow a Win XP cd from a friend and do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re installs the Windows files. This is great because when it works and you don't need to reinstall all your software.
Thanks, Joe
Oct 13, 2008 | Computers & Internet
DRIVES ARE NOT OPENING AND IS SAYING THT IT CANT BE OPEN INWIN32 MODE
hi, some system files are missing or corrupted. please try system restore utility or try a system repair.
Thank u
Jun 25, 2008 | Microsoft Windows XP Professional for PC
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Open Questions:
Gateway MX7118 Notebook Logo
130 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
