Question about Hotpoint TDC32 Electric Dryer
No water collecting in my hotpoint aquarious cdt00
There does'nt seem to be any water collecting in the water drawer, i have cleaned all the filters, looked and cleaned out the pump unit at the back. But still no joy.. can anyone help? thanks..
  • Hotpoint Master
  • 3,463 Answers
If you pull out the front left bottom filter and feel inside and find that it is wet, then there is a blockage, this stops the water getting to the water container.
Clean as much fluff and gunge as you can from this compartment, and feel for and locate a small drainage hole at the rear, get a plastic bag tie or similar, and poke the hole clear.
Hopefully, this will solve your prob.
Plz rate my solution.
Thanks.
I am assuming that the pump is working o/k
Posted on Jan 07, 2009
Water not collecting at base of pull out drum
hi make sure condenser box is clean that is one with metal plates if so make sure were filter goes is clear maybe blockage
Feb 12, 2014 | Hotpoint TDC32 Electric Dryer
My Hotpoint Aquarius Condensor Dryer seems to be collecting water behind the filter unit at the bottom of the machine. The drawer where the water is supposed to collect is empty. I keep the filter unit...
there is a line/tube the runs into the back of the drawer which is clogged, you will need to take like pipe cleaner or a stiff wire and run it into the the drain line/tube , Tim
May 29, 2011 | Dryers
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
Hotpoint CDT00 Tumble Drier has No Heat
you need to check the heating element also check the front drum supports they ussually wear out causing the tub to rub the element this causes the element to burn into
Jul 11, 2009 | Dryers
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Thanks.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
CDT00 Drying takes ages, water tank does not fill
check all seals are clear and free from dirt, also there will be a heat exchanger (usually located above the sump) this must be clean and free from dirt this does all the work so if the area is not clean it will take longer to dry.
Dec 11, 2008 | Dryers
Hotpoint condenser dryer CDT00
how to connect the dryer belt to the motor is there is two pullys.
Mar 30, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Jan 19, 2008 | Dryers
Hotpoint TDC32 Electric Dryer Logo
204 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
