Question about Technics SCEH790 CD Shelf System
Switching on by itself
Technics SA-EH770 start to switch on by itself after i switching it off.
  • Anonymous Mar 22, 2014
    no nomal sound output
    Genius:
  • 1,175 Answers
Hi...
Try covering the little red window that has the wireless remote receiver behind it. See what happens.If the problem quits,your stereo is picking up some other IR source in the room.
Also,shoot some WD40 into the cutout around the power switch
( WITH THE POWER UNPLUGGED) push the switch on/off several times then plug the AC back in.
Posted on Jan 11, 2009
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
My technics eh770 cd player is skipping so i now can't play cds
If the laser pickup is skipping, it is near end of life. Buy a CD cleaning kit and follow instructions, if there is no change the laser pickup assembly will need to be replaced, not cost effective to repair far cheaper to replace player.
Jun 09, 2012 | Technics Audio Players & Recorders
I have connected my Akai AP A510 turntable to my Technics SA EH770 but i don't get any sound till i turn it up on full, can you help
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn
Feb 21, 2011 | ION Audio Audio Players & Recorders
My Technics SA-GX100 Reciever worked for a minute, but when i set it up with all the speakers and attachments, it says "muting". i dont have a remote, so how do i UNMUTE it?
According to my Technics SA-R210 manual to UNMUTE without the remote....do the following......PRESS BOTH THE VOL UP & DOWN CONTROLS & THE LOUDNESS SWITCH ON THE UNIT AT THE SAME TIME......Not sure it will work for your model but that is what it shows for The Technics SA-R210 model, so it should be pretty much the same
Sep 04, 2010 | Technics SA-AX720 Receiver
When I turn on my technics sa-gx amplifier I can't hear the sound
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Jul 28, 2010 | Technics SA-DX750 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
No, I made sure the "a" and "b" indicators were lit. Have tried it with "a" and "b" separately as well. The right channel went out first followed by the rest.
Found the relay for the front speakers not switching. The relay was soldered to the board so I just rigged the contacts together effectively by-passing the relay. Works great now.
Nov 23, 2009 | Technics SA-DX950 Receiver
When switching on 'f61' appears on display
check the fan can be faulty,if the fan not the faulty then your audio ic is faulty-replace
Apr 05, 2009 | Panasonic Audio Players & Recorders
Technics SA-AX720 AMP
The audio amplifier IC of your device are damaged you need to replace it.
Jul 04, 2008 | Technics SA-AX720 Receiver
Video Problem
You most likely have either bad connections from the jacks to the main PC board or the video switching chip has an internal problem. Try resoldering all of the input jacks first and update this with your results.
Dan
May 12, 2008 | Technics SA-AX730 Receiver
Technics SCEH790 CD Shelf System Logo
152 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
