Question about Welbilt MR622W Microwave Oven
Holes in microwave wall due to arcing and contact with metal rack
There was arcing in my microwave oven which resulted in the metal rack starting to burn holes where it came into contact with the smooth finish on the wall of the microwave. Can the holes be filled in and the finish painted and will it be safe to use? Without the rack the microwave works normally despite the damage to the interior surface.
  • Anonymous Feb 16, 2009
    I too have the same problem metal rack left singe on oven wall. Help is it safe to use and can it be repaired?
  • angelabharri Feb 25, 2009
    the metal rack in my range microwave slid off its track and came into contact with the interior wall..there was a quick electrical flash and I turned it off..now, I notice slight scarring to wall..the size of a dot...is it safe to use? what could happen?
  • 37 Answers
The only thing you can do is replace your microwave
Posted on Aug 30, 2009
    New Friend:
What is the coating on the racks
Posted on Sep 02, 2013
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: the interior surface is rusted and arces sometimes
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jul 19, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Metal rack inserted backwards
It will just have to be sanded smooth and clean and dried thoroughly.
Posted on Mar 06, 2009
night71
  • 328 Answers
SOURCE: Maytag Microwave MMV5207AAQ
It seems to be a problem with many microwave ovens that support the metal rack. Microwaves are not perfect for the metal rack and often causes pitting in the metal where it gets too hot. You can get the racks redone but looking for a new one may be cheaper. Some racks have a better coating on them.
Posted on Dec 10, 2007
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Sparking in microwave (aftron make)
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
Brown spots on window of microwave
see this steps and fix it.God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Jul 29, 2013 | Microwave Ovens
    Rust or brown spots on window of microwave
    Microwave when turn on making a noise and sparks comin from fan area?
    Waveguide Cover
    Rack Support
    Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
    ELECTRICAL POPING SOUNDS
    Hi there - I assume you have a rack in the Microwave. What happens is the rack due to putting something in and out of the Microwave some times wears against the back wall of the cooking chamber. As this happens it wears through the paint and exposes the metal casework.
    You then get microwave arcing between the metal rack in the microwave and the cooking compartment casing which gives that spitting popping sound. I would say get some white model paint and paint over the scorched spot (as long as its not gone so far as to wear a hole in the case work).
    Wait for it to dry and stick the rack back in and try again to warm up a cup of coffee or something and see if it stops.
    Also if you pull the grill slightly forward in the holders towards the door and test it you may notice that it doesn't pop as much so I would paint it and pull the grill forward and see if you still get the issue.
    Best of luck.
    Sep 04, 2008 | Whirlpool GH7155XHS Microwave Oven
    Microwave Arcing
    The metal shelf that comes with most microwave ovens must NEVER come in contact with any surface of the cavity wall or arcing will occur. (this is why its is mounted on plastic clips). IF you are not using the shelf to cook multiple items (as most people don't)....Remove the shelf and store somewhere else until needed.
    Jun 06, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    Microwave Ovens Logo
    1,691 people viewed this question
    Top Welbilt Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
