Question about Exercise & Fitness
Irnoman Legacy treadmill error code E44
We have an Ironman Legacy Treadmill (purchased in Jan 2007 from Costco.ca)...has been running fine and recently recieved an E44 error code upon turning it on. The treadmill will not calibrate either. Called Ironman, and they have apparently gone bankrupt, and their business is apparently being taken over by the treadmilldoctor.com. I contacted them and was told to call back in one week, as they had not yet received the manuals so could not help me.
Anyone with this problem? Any suggestions?
We would love to have our treadmill back up and running and the 2 of us use it 4-6 times per week.
Thanks!
  • 40 Answers
SOURCE: model 150T Ironman Treadmill..motor has gone out
http://www.ironmanfitness.com/docs/man/treadmills/man-150t.pdf
there is the manual, but I need more info on your motor problem and what kind of belt adjustment you need to make.
Posted on Nov 01, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
SOURCE: Ironman M2 treadmill starts but then stops right away
Thanks, that advice pointed me in the right direction - if anyone else has same problem , I checked the sensor which was mounted beside motor fan and everthing looked ok - the distal end of the lead from the sensor to circuit board, was not easily visible as tucked under the motor - It clips into the circuit board here and that had come loose - once clipped back in , problem sorted.
Posted on Feb 06, 2010
SOURCE: Error code "SI 2" for ironman triad treadmill
You need to replace the motor control board located in on the base. If your both motors work along with your display added that you've done the reclibration then you must replace this board. I did and the unit works so far. 200 dollars is what you wil be spending.
Posted on Apr 16, 2010
SOURCE: Why does my Ironman Triad treadmill motor slow
When running or walking on my Ironman Triad Treadmill it jerks like it is going to stop every once in a while not all the time. Do you have any idea what makes it do this. I have had this Treadmill for 5 years and never had a problem before.
Posted on Apr 21, 2010
What is error code Hr in the 2007 subaru legacy?
There isn't actually an "Hr" code, but there is this code for the high speed CAN network communication failure. If you've had your car worked on recently I would take it back to whoever worked on it last and have them check it out. Usually caused when someone doesn't tighten a ground wire back up for some reason. Here is a Subaru TSB that covers some of this. http://ww2.justanswer.com/uploads/n9320h/2010-07-16_222648_sub.pdf
Er HC High speed CAN communication failure
Aug 28, 2014 | 2007 Subaru Legacy 2.5i SE Sedan
E44 on left screen, 123 on right screen of ironman 150t teadmill
I am trying to track down a similar solution, with no luck so far. I will keep you posted. Am trying to clear a message regarding perform maintenance. The machine will not run at all.
Feb 28, 2014 | Ironman 150t Incline Motor
E44 = ?
Good Morning bennysia28 - Typically, error code E44 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
May 08, 2013 | Electrolux Washing Machines
How do I fix an E5 error message on an Ironman 2300.1 treadmill? What does this error message mean? How do I get a manual for this treadmill?
go to www.fitness.manualsonline.com or www.iconservice.com and download for free.
E5 means a key stuck ,some Upper PCA has been failled.
Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 30, 2012 | Ironman Exercise & Fitness
Ironman treadmill shows code SI 1. what is it? how to fix?
The SI 1 error code means there is no safety key in place. Unplug your treadmill, wait a few minutes, then plug it back in.
When you try to use it again, make sure the safety key is firmly in place, and make sure the metal piece below the Emergency Stop sticker is still in place.
If neither of these work, it may be appropriate to take your treadmill to a servicer.
Hope this helps!
Feb 21, 2012 | Ironman 220t Programmable Treadmill (225...
Why does my Ironman Triad treadmill motor slow when people try to run on it, the belt completely stops
Dec 19, 2009 | Ironman Exercise & Fitness
Epic 800 MX Treadmill Feels Different....Bumpy
I have EXACTLY the same problem with my EPIC treadmill, purchased at Costco a few years ago. It just started today!
Jul 07, 2009 | ADVANTAGE Exercise & Fitness
Exercise & Fitness Logo
660 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
