Question about Frigidaire FEF355 Electric Kitchen Range
Frigidaire range Oven continues to heat up and will not shut off. I had to shut off at the breaker. range is 5 years old. turned breaker back on and it started to heat up immediatly. the last thing the oven was used for was broiling and it worked fine then. thanks
  • Anonymous Mar 18, 2014
    turned off and breaker back on to no avail
  • 883 Answers
Narrow it down to either the broil coil (upper) or the bake coil (lower). then find the control knob which sets each function and then replace that complete knob assembly.
Posted on May 31, 2007
Fes355dsb oven not heating
Good Afternoon Friend,
I understand that the oven is not heating in you Frigidaire range, model# FES355DSB. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and preheat your oven. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire range model PLEF398CCC
Turn off both breakers and then back on. Then check the wiring from the receptacle to the plug, to the back of the oven. This should be where the problem is. You particular model may have replaceable internal fuses. Look for them in the back of the oven. They are slow blowing fuses and can be checked. You won't be able to tell they are blown just by looking at them.
Feb 03, 2009 | Frigidaire Ovens
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
My manual clean oven range
you really don't need to remove them if your nervous just turn the power off at the breaker but they wont hut you as long as the oven isn't on
Jan 18, 2008 | Kitchen Ranges
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire FEF355 Electric Kitchen Range Logo
202 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
