Question about GE Radio Communications
I dont know what kind of radio i have
I need a new mic for my 2-way radio in my truck. its a ge but the model # has been worn off. the old mic is a CES model 600L. it had the dial number pad on it but i don't require that feature anymore. can you help me find a new mic to fit my radio?
  • Tyler G May 11, 2010
    submit a pic of it.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a CES- 600L is a DTMF encoder microphone with lighted keyboard. For your need:
  • almost always, the simplest requirement would be a 600 ohm mic and a PTT switch;
  • minimum of 3 wires are needed for a 2-way radio microphone to work;
  • 1-mic audio;
  • 2-PTT switch (must go to ground when PTT pressed to TX);
  • 3-common/GND;
  • in some, 4-RX audio (not needed if radio receives with no mic).
Having said the above, then any replacement microphone with appropriate microphone plug/jack could be wired to match the GE. A generic example is shown below.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 11, 2009
Where can I get a mic lead or mic and lead to replace the worn damaged lead fitted? The radio is a NAVMAN mcb7270 27MHz marine radio.
dont know how to open it but you can buy most cb radio stuff at ebay or amazon. i have seen a lot of these radios on ebay. and you can google it as well. plus if you dont see anyway to open it you probably just need to replace it. hope this helps. believe me i learned the hard way when it comes to things that have no screws.
May 27, 2016 | Radio Communications
How do I wire a MIC on a Cobra 29 LTD classic 4 pin mic?
would need to know the mic wire code you going to use. but half moon cut out at top as you look at it is top left 1-4 next row left side 2-3. 1 is cable/ unshield (common). 2 is MOD 3 is TX 4is RX... 1 is wire with no cover 2 is with cover rapped round wire RX is received TX is transmit, hope this helps. newer mic have different code wires so check with meter, red green and blue and shield is on some of the new wiring.
Oct 10, 2014 | Cobra 29 LTD CB Radio
Cb troubleshooting
Sounds Like a wire is broken on the mic connector. Disassemble the microphone plug and check the connections. Also There is a relay inside the 139XLR that is quite old by now and could possibly be worn out or dirty.
Jul 04, 2014 | Radio Communications
I have a cobra hg m73 mic and the wire broke.i dont know the pin color code
it depends on what kind of radio youre using and how many wires are in the mic cord
Apr 06, 2013 | Cobra Highgear 70 Hg M73 Standard Dynamic...
I just got a rca co-pilot cb and i would like to know what kind of power mic will work with it can you help me
any mic will work on any radio. just need the right wiring or ohm impedance(new mic on old radio)..
Feb 03, 2011 | Magnum DeltaForce CB Radio
I NEED A DIAGRAM TO HOOK A NEW PLUG FOR A RADIO
we need to know what kind of mic are you hooking to it?
Dec 19, 2009 | Radio Shack TRC-447 CB Radio
I have a midland twoway radio I dont know if its a VHF or UHF model # is 70-530B also need mic wiring thank you...
It is a 25W UHF radio 445MHz-455MHz
Type accepted for land/mobile.
Sorry, no info on the mic wiring.
Oct 04, 2009 | Midland Radio Communications
Transmit buton
Yes as long as the features and pin configuration of the connectors are the same. In its simplest form, the microphone/cable would only be carrying 3 wires; transmit audio, PTT to TX and ground. Of course others would have for the different switches, keys and other features (if present in your model).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 19, 2008 | Uniden Solara - VHF Marine 2-Way Radio
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Radio Communications Logo
183 people viewed this question
Top GE Radio Communications Experts
Greg Cann
Greg Cann
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
