Question about Janome 6019QC Mechanical Sewing Machine
How do you get side cover of machine off? Janome 4800 mc.
Need to retrieve bobbin winder stop and screw as came loose and it has slipped inside machine.
your help would be appreciated as need to use machine a.s.a.p
thankyou Sylvia.
Problem fixed...........called in an engineer.
Posted on Jan 08, 2009
Bobbin winder not winding cotton on spool a part has fallen in side machine how do l take casing off Janome 480 quilter thank you
Am unable to help with your machine but you can purchase a stand-alone bobbin winder called Sidewinder for about $30. Just be sure to verify that your machine bobbins will work on it. The one I have will use either a power cord or batteries. Great little machine because it saves wear-n-tear on the machine plus you can wind bobbins without unthreading the machine.
Customer Reviews Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Portable Bobbin Winder
Amazon com Simplicity SideWinder Portable Bobbin Winder
Jun 05, 2017 | Janome Sewing Machines
Janome 660 sewing machine has broken bobbin winder spindle. I can order a new spindle, but cannot get the cover off of the machine. all screws are out.
You can purchase a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or for ~$25.
Dec 02, 2015 | Janome Jem Gold 660 Sewing Machine
My bobbin winder will not turn correctly
Ok this solution may be obvious but I'll say it in case you haven't tried everything; when you put the correct bobbin on the post,it has a slot which lines up with a metal spring on the winder post and makes an audible SNAP. Also you need to have the post with bobbin in place firmly snapped to the right for it to wind properly.Also check how you have the thread coming to the bobbin,follow the diagrams precisely.If it still doesn't work well, go buy a bobbin winder they're much easier anyway! Good Luck!
Jun 27, 2014 | Janome Memory Craft 9000 Computerized...
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
Jul 11, 2009 | Janome Memory Craft 9000 Computerized...
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
Nov 25, 2008 | Janome Memory Craft 9000 Computerized...
Designer 1 bobbin assembly loose or broken. will not allow machine to function. trying to take cover off machine to remove bobbin assembly so I can use machine until I can get it to repair.
If the bobbin winder spindle is loose and flopping around in the opening in the front of the machine is has come out of the frame that it should be mounted in. Operating the machine with loose parts inside can be risky for the machine and the operator.
Don't take a chance on causing further damage to the machine. The bobbin winder can be replaced without too much trouble and is relatively inexpensive.
May 14, 2008 | Husqvarna Designer I
Janome 6019QC Mechanical Sewing Machine Logo
127 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
