Question about Kenmore Elite HE4 Electric Dryer
I have the he4 smart dryer and it takes way to long to dry
The dryer takes more than 4 hours to dry my towels, this just doesn't seem right
    Scholar:
  • 91 Answers
Cleaning the lint filter after completion of a dryer load is part of the regular care and maintenance of your appliance.
First, make certain that the ventilation hose doesn't have any obstructions in it. Second, make certain that the ventilation hose is positioned properly to allow the air being vented to flow freely. Make certain that the lint screen and lint duct is clean. Check the fuse and heating element.
And also the Washer,Maybe it is not spinning the clothes dry enough.
Remove the vent from the rear of the dryer and see if there is wet lint and possibly water in the hose. Find if there is blockage in the vent hood and inside the hose(like a kink). Clean or replace the venting and your dryer will work like new.
All the best
Posted on Jan 07, 2009
    Sergeant:
    Novelist:
  • 326 Answers
Its because of two things.either the heating element is faulty or the thermostat is faulty.also it is quite possible that the vents from which the heat reaches the compartment are blocked. this things need to be checked .
  • 3,037 Answers
Hi rachie
It sounds like the heating element might have gone bad and needs to be replaced. How long have you had this dryer and are the towels hot when you take them out? You should also check all of the vents to make sure you are getting proper airflow.
bestdarngood
    Brigadier General:
  • 8,619 Answers
Hi! Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Also, Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, check it
  • Rylee Smith
    Rylee Smith Jan 07, 2009
    I think the motor is not running at the desired speed and thats why it takes 4 hrs to dry and also check that it may not be spinning in opposite direction (which occurs due to ground short with main )
  • Rylee Smith
    And also check for the blower motor.
    Genius:
  • 3,422 Answers
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
  • 4,806 Answers
Hi there
The heating element or the thermostat has gone faulty, calling an engineer would be a good idea
Good luck and kind regards
My electric dryer takes a long time--3 hours or more to dry a load of wet towels
The heating element may have failed. Also, the vent may be clogged.
Aug 15, 2016 | Kenmore Elite HE4 Electric Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Yes i have a Kenmore Elite Smartheat quitepak 9 HE4 and its not drying at all. It takes 180min on hight to dry towels
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, double check your installation, first, to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Sep 22, 2010 | Kenmore Elite HE4 Electric Dryer
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
Takes hours to dry small load
You have a build of of lint inside the unitm which is cutting air flow. Look outside at your exhaust. clean it and check how much air flows out.
Aug 30, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer seems to be hot, however it takes forever to dry a load. Is 3 -4 hours normal to dry towels?
Your heater coil has burned into 2 parts. Find a friend WHO IS KNOWLEGABLE about dryers, Call a repair man or find a good used dryer. I understand this isn't what you wanted to hear, but this involves lint and 220 voltage. NOT to be taken lightly. The coil will cost around $50 and the repair men will be a minium of $75; Look in the paper and buy another one....
Aug 25, 2009 | Dryers
It now takes 2 hours to dry towels
lets hit the eazy button first.dry a load with out the venting[wont hurt a thing]if ok its the house venting,if not dryer .GE is only brand that has two elements.so if not ge and heating element ok and its blockage in the dryer.hope that helps God bless ,tom
Jan 04, 2009 | Dryers
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
