Question about Garmin eTrex GPS Receiver
Display The display of the etrex now has horizontal lines across all screens. The lines distort the display and make the unit difficult to use. Any suggestions?
  • TermiteHunt Jan 19, 2008
    Horz blank lines. First appeared after not using for some time.
  • hubpounder Mar 30, 2008
    Magellan Explorist 200 has horizontal lines through the entire screen which makes text appear distorted.
  • 35 Answers
The problem is a physical one, not a software issue.
I assume some sort of loose connection(s) at the screen or failure in the hardware.
Have been reluctant to dis-assemble without advice/guidance from someone that has experienced and solved the problem.
Can not update software as no link cable comes with unit.
Recently attempted to construct one ( found directions online for home made version) but needed a different type of wire than I had available at the time. (cost to purchase one from Garmin prohibitive for my uses) I have repaired an unresponsive Dell Axim x5 screen by dis-assembling and placing tape over a burnt ribbon connector so I am not afraid to work on the unit provided some success is possible. Not knowledgeable enough to just look for something that might not be apparent to the untrained eye with the risk of damaging the unit further. The unit is usable just difficult to read.
Posted on Apr 01, 2008
  • TermiteHunt Apr 02, 2008
    This is not the "thin black line display only" problem
    The screen is for the most part visible. Several horizontal rows of pixels are not on (black where it should be) but rather always off (no image) Some in groups others alone. Apparently random but always the same on all pages all the time, every time.
  • Garmin Master
  • 638 Answers
Update the unit software and please report back if this fixes the problem.
  • TO Lady Apr 02, 2008
    Some of the Garmin Legends displayed this exact same problem (screen not displaying except for thin black line), and most were cured with a unit software update, this is why I suggested this. I can't help you with any internal tinkering. Maybe someone else can jump in here on this?
Have samsung un55c9000zfxa led tv with horizontal lines across screen can it be fixed?
It's either the control board or the display itself.
You'll have to find a TV repair company. They won't be able to tell you for sure until they test it, and they may charge you to test it. The control board should be a cost effective fix, the display won't be.
Unless you're trained in Electronics, don't open up the unit and try to fix it yourself, there are hazardous voltages even when the TV is unplugged!
Jul 18, 2016 | Samsung Electronics UN55C9000 - 55in 9...
Just replaced my vizio 4kUHD LED main digital board, but am still having horizontal lines causing screen distortion.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 07, 2016 | VIZIO P502ui B1 50 Inch Ultra Smart
Sony model KDL32L5000 has a black horizontal line across the display. above the line picture is fine, below the line display is distorted... any ideas?
Faulty vertical deflection section. check the yoke vertical winding. maybe its cure from service mode. search online how to apply service mode of you tv brand, model and board chassis number.
Aug 17, 2014 | Televison & Video
Thin white line across laptop screen
check lcd display data cable if cable is fine problem in display unit
Apr 27, 2014 | Computers & Internet
My 3 year old Garmin Etrex Vista just started displaying horizontal lines across the entire display. Any suggestions?
Try updating the unit's software via the Garmin.com website. This may fix it as there was a satellite launched which was causing problems with some Garmin units.
Sep 25, 2009 | Garmin eTrex Vista GPS Receiver
Horizontal lines on screen.
Your unit may have a loose connection from motherboard to the display (video cable inside the unit), another distinct possibility is that the video processor chip is damaged or there is a power supply problem for the video chip (a bad electrolytic cap or similar somewhere around the video IC).
You can check the connection, but you'll need to take the unit apart, also check other connectors, but if it's an IC problem, this could get difficult or/and costly.
Please note that these are only suggestions and that the problem may as well be something else.
regards
3rq8 (Triarcuate)
Jul 23, 2009 | Audiovox D2010 Portable DVD Player with...
LCD screen display is broken up
Try updating your unit's internal software via the Garmin.com website. There was a new satellite launched which has caused problems such as this, and the update fixes it.
If this solves your problem, please come back and tell us, and rate our solution. Thank you.
Jul 08, 2009 | Garmin eTrex Legend GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Feb 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Garmin eTrex GPS Receiver Logo
253 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
