Question about Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum
I'm trying to find the brushes for my Kenmore Power Spin, but I don't see this option nowhere.
  • 1,673 Answers
Find the model number, then go to, click on parts and put in your complete model number, you should get a parts list and image, you can also order on-line thru Or pull out the brush block and go to a service shop that does Hoover and see if they can match it up.
Posted on Jan 08, 2009
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Kenmore vacumm cleaner power head
Whats the problem. Brush don't turn or etc.
Jan 13, 2012 | Kenmore Vacuums
Same problem as skatemom;brushes wont spin tried reset button model 11635922502
Check that the belt is in position, not slipped or broken. This is what turns the rod with the brushes.
Aug 17, 2011 | Kenmore 31913 Progressive Direct Drive...
I have a Kenmore "Intuition"
I had a different vacuum that did this. I took all manner of things apart looking for blockages and the like .I found that by having the vacuum handle in the full upright position shuts off the suction to this area and doesn't power the brush BY DESIGN. I think this is to get more suction to the hose.
Dec 18, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Agitator unit on Kenmore Progressive 116.25915503 won't spin. I have cleaned out all hair and string wrapped around it. Belt is good. It seems to spin on one side but stuck on the other. Could string be...
Pry the end caps off the brush bar, you will find hair and string wrapped up tight in the end. the bearing may also be shot, you can try and oil it up a bit to keep it spinning. <!-- from fixya rte -->
Oct 21, 2009 | Kenmore Vacuums
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
Generic problem for all Vacuums
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum Logo
119 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
