Question about Hotpoint Dryers
Replacing bearing kit and noisey
Pictures of tdl30s
  • Hotpoint Master
  • 8,220 Answers
Rear bearing WE3X75
Posted on Jan 07, 2009
Rear wheel bearings
This vehicle has non servicable bearings. These bearing/hub assemblies can last the life of the vehicle. If one becomes noisey/loose then replacement is necessary. There is no actual mileage replacement interval.
Jun 07, 2015 | 2009 Kia Spectra
Toyota hilux 1989 2-4pickup how to adjust front wheel bearings
Remove grease cap and split pin jack up the wheel and spin it and listen for noisey bearings if all ok tighten the large nut up and then undo it till it is just no movement in the wheel when you rock it in and out then fit castle and fit new split pin.
Dec 15, 2013 | 1989 to 1995 Toyota Pickup 4WD Front...
My dryer, after it heats up, makes a sound like the bearings might be going out. Is this a common problem? Or could it be something else?
it sounds like the roller on the belt tensioner is basd the bearing get hot and expand locking up the bearing causing a noisey sound. if left alone it will cause a banging noise later on. Sears sells the roller and belt in a kit form for most makes of dryers
Apr 20, 2010 | Dryers
Can anyone explain how to grease the bearings on a Dyson DC14 vacuum and if theres a how to video or picture website that is available for reference??
Not sure what you mean when you say "grease the bearings". I am not aware of any bearings that can, or indeed ever need, greasing in any model of Dyson. The motor bearings are sealed for life and if noisey ths can only be properly cured by a replacement motor. The clutch is a sealed mechanism so again, if noisey must be replaced. Finally, the brush or beater bar bearings at each end are plastic on metal, so should'nt produce any noise anyway.
However, if you do want to dismantle your machine have a look at www.dysonmendic.com and look at the DC07 section (the DC07 is very similar to the DC14), this will give you a lot of information on how to dismantle your machine.
Mar 25, 2010 | Vacuums
Where is the rear bearing located so i can grease it
The rear bearing is not accessible to grease. If you have a noisey spin that sounds like it is coming from the bearing it will have to be replaced. Most tub bearings on front loaders are preinstalled with the outer tub assembly. It is a major job to overhaul a front loading machine, requiring outer tub assembly, water seal kit and possibly tub gaskets. If not under a warranty it is not economical to repair.
Feb 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
Dryer squeqks while rotating
It could be a noisey idler pulley that belt rides on, or a noisey drum bearing or drum glides, or even possibly a motor bearing going bad. Would need to be checked by repairman to determine exact cause.
Feb 04, 2010 | GE DBXR463GB Gas Dryer
I have changed the Clutch kit without pilot bearing
Only if it is noisey. It would have been advised when the box was out but now it is back together it isn't worth the effort... you'll be fine :o)
Nov 20, 2009 | 1999 Suzuki Vitara
Noisey drum, can bearings be replaced on zanussi zwf 1421 w
Yes they can. Search for a service manual for instructions, on the net. Parts are not usually exspensive, Repairmen are. I did mine in less than an hour.
Andy
Nov 09, 2009 | Zanussi F1045W Front Load Washer
Noisey when runing with a load
your dryer bearings are going bad there is one directly behind the tub and you need to take the front off and take tub unit out and you will see the bearing directly in middle of back of tub
Jun 01, 2009 | Maytag Dryers
Noisey gearbox bearing in r33 skyline how hard to fix
U will need to replace all the gearbox bearing's, not just one, there is a bearing kit(s) u can buy for most manual transmissions, but u will need a factory service manual to have any real hope of setting this trans up right when u put it back together. On a scale of 1-10 10 being the hardest this is a 9 for an untrained technician.
Apr 02, 2009 | Nissan GT-R Cars & Trucks
Dryers Logo
61 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
