Question about Minolta EP4000/5000 CS/PRO Copier
Copies shows: Call Maintenance M2
It is a Minolta 4000 CS Pro copier. What type of problem does M2 indicate?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Posted on Jan 07, 2009
Minolta 4000 insert key
There is device slot where the Key Counter goes who ever owned the machine before you had it set up like at Kinko's where you get a key from the store make your copies come go back to the employee and they determine the number of copies you made. Mite want to get the key previous owner.
Dec 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 4000 Copier shows: Call Maintenance M4
stop 0 stop1 sets the machine service mode. select consumable clear the copy kit counter
Mar 31, 2012 | Minolta EP4000/5000 CS/PRO Copier
Preventive maintenance time code:M2
just enterto tech rep mode stop 0 stop 1 then select funtion then find maintenance counter then reset the maintenance counter
Nov 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
My minolta ep 4000 copier prints with thick black streaks imprinted on page. what's wrong? is it the corona, the drum, or something else?
Most likely it is the drum cleaning blade. One indicator of the drum cleaning blade going bad is that the black lines will get worse as you run multiple copies. So if you make 10 copies for example, the last copy out will be streaked worse than the first copy out. Drum cleanig blades are about $30 bucks plus whatever your local service guy charges for a svc call.
Good Luck and Thank You for using Fixya.
Jul 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Mar 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
How to clear M2 on EP 4000
TRY CLEAR DRUM AND OR WEB COUNT.it has to do with parts count
Sep 12, 2008 | Minolta EP4000/5000 CS/PRO Copier
Service
it means it time for the cleaning web, and waste toner bottle to be replaced. once you replace it you can reset the indicator.
thanx,
mikey
Mar 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
1,374 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
