Question about HP Deskjet D1430 InkJet Printer
My printer wont print or respond lost my program to reinstall need to find a new program
  • 119 Answers
    Sergeant:
  • HP Expert
  • 424 Answers
Alternative driver download link: HP Deskjet D1430 Printer Driver
Posted on Feb 01, 2010
LOST INSTALL DISC
just go to google and type your printer model and download drivers for the same.
Nov 07, 2013 | Zebra Eltron LP 2543 Thermal Label Printer
My printer will only print the top or bottom half of words
This sounds like your word program and not your printer. The information from your word program is not being sent from the DLL correctly. Try a different word program or try reinstalling word.
Phill
Jan 15, 2013 | Office Equipment & Supplies
Will not respond when I send to print
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similar options also you can troubleshoot the device
you might have many prints backed up ((make sure you have the printer turned off)) otherwise it might print another page
if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a
display print queue tab you can see all prints right click on the ones you don't need select cancel
hope this helps
Jun 06, 2012 | HP Photosmart C3100 series
Wont let me print
Sounds like your puter has lost contact with the printer. Unplug the USB or Parallel cable and reconnect. If that doesn't work, you may need to reinstall the printer driver.
Jan 22, 2012 | Ricoh Office Equipment & Supplies
Our HP DesignJet 500 will not print.
If they changed the server queue, or possibly did not even reinstall the printer queue on the new server, all is not lost.
First try connecting to the printer directly using USB or parallel if that's an option. If you can set it up as a local printer and that works, at least you know the printer is fine.
If you can print a diagnostic page with all of the specs of the printer, you can find the IP address and print directly to the printer, bypassing the server print queue. You can also find it in the Setup, IO Setup section of the printer's control panel.
To create an IP print connection, add a new printer, choose local printer, then choose "create a new port" of type "Standard TCP/IP port". Then enter your printer's IP and point to the driver as before, and you should be able to go direct.
Jun 10, 2009 | HP DesignJet 500 InkJet Printer
Wont print was working 4 days ago
You need to completely remove the printer driver and all software for the printer, and then reinstall it. That should fix you up.
May 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Not printing even with new ink cateridge
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 08, 2009 | Lexmark X2650 All-In-One InkJet Printer
HP PSC 1510 All-In-One-Printer not responding
Normal 0 Driver could be corrupt.
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printer wont print says it need xprt6.dll reinstall
You have to reinstall the printer driver
Go to control panel and select printer tab
there is your printer
right click and delete it or
go thrught the programe and uninstall the printer
then reinstall it
Aug 01, 2008 | Office Equipment & Supplies
Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Feb 27, 2008 | Zebra Eltron LP 2824 Thermal Printer
HP Deskjet D1430 InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
