Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
Frigidaire front load model FTF2140FS1, will not drain in the normal cycle, and you must add a drain/spin cycle at the end. Just moved it over 3 feet to the left, was working fine prior. No real change in hose position, and works great in drain/spin setting. Why work on one setting and not the other? Just a few months old, and was fine before the sight position change.
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: washer will not drain on regular cycle
The problem is certainly related to drain hose and or outlet connection.
Make sure it is not trapped or kinked behind the washer.
Changing the position of the washer could esily have caused the hose to twist and restrict the outflow of water.
Plz rate my solution.
Thanks,
r.
Posted on Jan 07, 2009
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not drain on regular cycle
Thanks,
r.
Jan 07, 2009 | Frigidaire Washing Machines
My washer wont spin
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
131 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
