Washing machine overflow drain upstairs
Moved to a new home with washine room upstairs.have drain pan under washer.where does the leak drain go? Mine appears to be plugged about 4 inches down.
  • 15,935 Answers
It goes to a pan under the washer where it will evaporate.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Water is leaking out from the bottom of my washing machine.
The leak can be from the drain valve/pump. from an overflow or from the tub. It can also be a loose fitting of the drain hose which can be clamp that needs to be tightened.
But first of all you need to observe under the washer with the help of good lighting. This observation will show you the area of leak and as mentioned the part can be taken out and reset.
if drain pump/drain is leaking , remove clean and reset. If overflow check the waterlevel sensor. also if the inlet connection is faulty at the inlet valve.
Feb 18, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
Why does my front loading LG overflow into the overflow pan?
Have you checked under the rubber gasket in front of the drain holes to make sure nothing is blocking it? Socks frequently get stuck here in my machine and can cause some leaking.
Dec 21, 2009 | LG Washing Machines
I have a brand new home (only living in it for a week) and we've noticed an odor coming from our upstairs laundry room which we think is coming from the Kenmore elite he3t washer/drain. Given that its all...
It is possible that the drain hose is placed too far into the home's drain stand pipe, but I'd check to see if you have any water in the pipe trap that the washer is using for draining out. With new homes, or even houses that have been vacant for some time, is that the water in the plumbing traps can evaporate and allow sewer gases to enter into the home.
Also, since this is a brand new home, you might want to try fishing a wire into the washer drain pipe to verify that a pipe trap is installed in that wash room. Not to cast doubt, but sometimes a trap doesn't get installed during the construction phase of a house and it gets forgotten. The ony way to check for this is to see if you hit any obstruction as the pipe makes the 180 degree bent. This "trap" is what holds a small amount of water in that bend, effectively blocking/sealing the drain pipe from sewer gases, etc.
Also, I suggest you leave the door to your washer open after you've completed washing, since even a small amount of water being trapped inside the wash tub, can lead to getting moldy/mildew forming and the smell that accompanies it. We've found that by simply leaving the door ajar after washing, we've been able to avoid those nasty smells and having to use special (more expense) tablets (whirl-out) and extra washing cycles just to keep the washer clean, etc.
Hopefully the cause is simply that the drain pipe is stuffed too far into the drain and has been siphoning the residual water out of the trap and readjusting the drain hose will solve your issue.
But don't be afraid to contact your builder/seller of the house and request they verify that there is a trap installed in the wash room.
Hope you find this Very Helpful and best regards!
Oct 22, 2009 | Kenmore Elite 45986 Front Load Washer
F23 error
Your washine machine has sprung an internal leak and is leaking water into the base pan, this should be checked by a competent repair person.
Jun 14, 2009 | Siemens WM14S794GB Front Load Washer
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader run with shipping bolts in
I would have sears replace the washer and also replace all the damage in your house. If it pulled out the drain hose there could be damage in there, if they are not willing to replace the machine then they should run a thorough diagnostic to make sure EVERYTHING is in working order, and still replace what is damaged to your house
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
Drain old water
hi thanks for the question. to drain washer.put hose on floor in bucket. this will drain your washer thanks. for the question the appliance doc
Oct 04, 2008 | Kenmore 22062 Top Load Washer
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
