Question about Dell E173FPb 17" TFT LCD Monitor
Dell monitor model 1907fpt not recognized in Ubuntu OS and defaults to 899x600. Am not able to find suitable fix on line. Please advise. thanx!
  • 827 Answers
I had a similar problem with my monitor.. I installed the nVidia graphics package from the Package Manager and then upped the resolution .
You'll have to make sure you know if your graphics card is nvidia or ati, though..
Hope this helps
Chris (ziraffa)
Posted on Jan 07, 2009
Ubuntu driver for SCH-U440
If Samsung don't list a suitable driver, there is none.
May 20, 2017 | Samsung Gloss Sch-u440 us Cellular Qwerty...
I have a Dell Optiplex GX620 and Dell flat screen monitor model 1907fpt. The monitor is flipped upside down and all of the answers I can find say to use Ctrl + Alt + Arrow or Ctrl + Alt +R and this does...
I am trying to remember if that is a radeon display chipset - if I recall correctly it is, and should be using the catalyst drivers. If the drivers are up to date, this is the solution.
You want to open the radeon vision engine control center, go to common display tasks, then desktop rotation, and choose landscape (non-inverted).
if you are not running a radeon chipset, or are not running the ATI Catalyst driver set then post a comment here and I will help you further.
Jul 20, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
I have a desktop PC with HP v72 monitor and a GeForce FX 5200 video card installed. I uninstalled Windows XP and installed Ubuntu Server 11.04. The problem is that after the initial boot screen my monitor...
why run server, , sure you actually want a server.. sure.
Linux, run the newest Ubuntu on new pc
or older on older pc, ive no idea at all what PC you have.
v72 old CRT , glass tube monitor a RELIC in today world.
why post OS questions lacking what HP computer you have of 1000s.
XP gone great idea, for sure....
OK F8 is Microsoft , for get them it not MS now, not at ALL.
in the Linux world its failing to find the correct minimum or
best resolution to match your old monitor
the monitor is year 2000.
the best resolution is 1024 x 768
you are using new linux, and it does not use that old old CRT
weak as a cat resolution,
you can use and older linux, or newer monitor
or change the resolution
using
if seen and done this 100s of time, endless,
btw your OLD CRT monitor does not use proper PnP plug and play
data comms.. its too old, why mess with CRTs in 2017?
walmart sells a $45 LCD , use that? and avoid darkages resolutions.
the way to do this is to run in command line mode
and change the config file, called, xorg.conf
https://techblissonline.com/ubuntu-804-set-default-resolution-1024-768-virtual-pc-2007/
there are other ways,
recompile the kernal to default to this reso? relic
or there is hot key at boot, read the manual on ubuntu
and change to lowest poor resolution
then run setups with a working desktop.
ask on a Ubuntu forum, it can vary by year, OS made and version
and what what desktop running of the many.
https://wiki.ubuntu.com/X/Config/Resolution#Resetting_an_out-of-range_resolution
keep in mind
your CRT is not supported now.
you must force it.
one more for V12, dropped the startup manager, wow....
best is to ask only for your version and choices at install time.
grub , KDE? what?
http://ubuntuguide.net/monitor-signal-out-of-range-problem-in-ubuntu-12-04-precise-fresh-installation
Jun 11, 2017 | HP V72 17" CRT Monitor
How to activation camera in ubuntu os
UBUNTU is a linux open source OS. Chances are your camera doesnt have a Linux driver and wasnt designed to operate under Linux. The website http://www.ubuntu.com/support/communityis the user support community for UBUNTU.. I would post your question there for assistance from someone with a similar model for your laptop. There is also a selection for real time chat support from other UBUNTU users. I have checked DELL website under your unit and it was made to run the Windows XP system so there are no Linux drivers available directly from Dell.
Jun 06, 2010 | Dell Inspiron 1000 Notebook
Poweredge 2300 - Ubuntu OS - belkin usb PCI card - not recognized
Check lsusb and see the list if u can find the root in the list
Apr 08, 2009 | Dell PowerEdge 2300 Server
Dell Monitor 1907FPt comes on for a short time and goes to a black screen. Power light is still on. How do I fix this?
HI
YOUR PROBLEM IS NOT INVERTER BOARD IT IS MOST LIKELY THE LAMPS, ANY 19" LCD LAMP THAT FITS WILL FIX IT FOR YOU.
THANKS
AHMAD
Mar 01, 2009 | Dell E173FPb 17" TFT LCD Monitor
Dell 1907FPt picture appears for three seconds, then off, LED power remains
I have the same problem. I talked to a few people and it is believed that the condition has been caused by a power surge.
My monitor is out of warranty, so I intend to open it up to check the fuse(s).
I will post result of that soon.
Aug 21, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907FPT lcd monitor
Could be the power supply. Get one at www.partstore.com. I've had very good luck with them fixing various LCD monitors.
Jan 08, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
139 people viewed this question
Alun Cox
