Question about Lexmark X125 All-In-One InkJet Printer
Lexmark X125 paper jam
I have a Lexmark X125 All in one inkjet printer and have a paper jam. I can't find anything as simple as a paper jam remedy in the manual. Can you help, please. Desperate technophobe.
  • Anonymous Jan 12, 2009
    i have never been able 2 use the machine because of this. it was supposely a refurbished machine. please help!!!!
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
Require printer installation drivers
I found these on the Lexmark X125's product page:
Install looks pretty simple; click Run, then follow the on-screen instructions.
For more drivers, check Drivers for Lexmark X125.
Oct 07, 2010 | Lexmark X125 All-In-One InkJet Printer
It keeps jamming and nothing is jamming it
Check inside the printer, look for the sensor and check is there a small piece of paper lodge in the sensor.
Sep 09, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Paper wouldn't go in or out. I pulled it out but
Here's an article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on a Lexmark X125. Just click on this link: http://bit.ly/bfgVWv. Hope this helps.
Jul 15, 2010 | Lexmark X125 All-In-One InkJet Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
My Lexmark X125 has an error that says paper jam but there in no paper in it what do I do
1.Go to Start->Settings-> and select the 'Printer and Faxes' option.select the printer and open it. Delete if any files are present in the queue.
2.Switch off power to the printer and switch it on again and see.
Dec 27, 2009 | Lexmark X125 All-In-One InkJet Printer
Need to know how to work fax machine for lexmark x125..need a manual..
First make sure the phone line is connected to the in on the fax machine. Then make sure you document is facing upside down. With the top going down into the fax machine. Collate the papers before doing this. If they are not collated they will jam up. Then there should be a scan and fax button or in the menus somewhere hit that option. Enter the telephone number where it you like for it go. Ffinally it the enter button.
Nov 23, 2009 | Lexmark X125 All-In-One InkJet Printer
I need help
Filename: CJXP125LE.exe File Size: 6.79 MB ( 17 min @ 56 kbps ) Driver for Microsoft Windows XP
Nov 19, 2008 | Lexmark X125 All-In-One InkJet Printer
Used Lexmark X125 Printer
change your printer cable athen probelm remains uninstall driver install again.
Oct 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Paper jam
remove all the paper from the papoer feed tray, open and close all the compartments that allows you to remove the paper if any is stuck.. with the paper out the tray, press the paper feed button or contine and this should work, if not unplug then plug back in.
Aug 14, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
220 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
