Question about Ovens
Nothing Working , but the Clock??
On Christmas noticed that the preheat light/buzzer would not go off no matter how long we waited. Once we explored we found that only the top element of the stove was heating- it kept the stove at a warm enough temp to cook ham and then we used broil at the end to ensure that ham was done all the way thru. During this time,'' ALL 4 TOP BURNERS'' were Working, so we decided not to use the oven-part till we replaced the bottom baking element, but seen NO HARM in using the top 4 eyes to cook with till we ordered an element and replaced it and got it back to working order again. So, we ordered a bottom heating element which came in yesterday and we had our handyman (who has some electrical background) start the process to change the bottom element. The IDIOT forgot to unplug or turn the main breaker and when he went to pull the bottom element out there was a small electrical ARC from the element hitting the side of the stove casing where it plugs-in. It was enough to make him jump back and realize what he had done. We turned the power off and then changed the bottom element. We then turned power back on, plugged in the stove and turned the temp to 375 to see if things were back to normal again- right way the preheat light came on as well as the clock flashing awaiting to be set to the correct time of day - we then set the clock to the correct time of day and then checked the 4 burners/eyes which now all of a sudden DO NOT work. After 15 minutes or so, we opened oven door to see if it was heating, since the buzzer did not go off to let us know the oven has preheated, and it was not working either( Top or Bottom element). So, now the Bake and Broil elements (Top and Bottom) inside the oven door are not working and all 4 eyes on the top of the range do not come on either????? Is there a reset button?- is there an internal fuse that may have been blown - please help- My wife and I are helping out my disabled father and he is thinking the worst. Thanks and if you need more info let me know. I can take digital photo for you I currently have the back two panels off, I was looking for a fuse, but did not see any. I will be waiting for anyones help-THANKS!! Bruce Pitzer
  • ridindirtynw Jan 07, 2009
    Technodeal, I appreciate your response, but to me that made absolutely NO SENSE !! Im not trying to be difficult, but you must understand that you will have to explain in more detail as to what I'm to do and HOW--I am not a repairman on stove so work with me in detail. I guess what I need to say now, is I need further assistance from someone else-Thanks
    The advice I recieved from "technodeal" was insufficient, I would like further assistance!
  • 328 Answers
In order to give you step by step instruction on what to try and how to go about it ,we are going to need the make and model of your stove..........(and please keep in mind it is hard to diagnose a problem when we cant see what you're working on)
thanks for choosing fix ya!
Posted on Jan 08, 2009
  • 3,037 Answers
Hi ridindirtynw
yes there is a fuse, it is located on the inside of the back panel of the oven. If that doesn't fix it, then the control board may have been fried when the arc occurred because you interrupted the current.
bestdarngood
Posted on Jan 07, 2009
  • Benjamin Patri
    Benjamin Patri Jan 08, 2009
    I'm sorry that the first response was so unsatisfactory. This website works by a way of consumers helping each other. Occasionally we get some responses that are less than ideal. I am more than happy to help you but please first look into my first comment. Thank you.
  • 177 Answers
Hello and welcome to FixYa!,
It sounds to me like there is a Fuse blown in the Oven which is causing only the Clock to work.
It may also be a Fizzled Electrical Circuit in the Oven.
Hope this helps, --P3NGYJ03
    Genius:
  • 1,239 Answers
Hi gerrie824 look at the elements and see if there is cracks in them. If so then yes they failed. During bake the broil elements come on in 1/2 power to brown the top of what you are baking. If there isn't a break in the elements, then the issue could be a burnt wire, failed relay, or such.
  • 242 Answers
I can help , normally the fuse is in the control board in the rear of the unit but it probably can not be removed , make sure there is 240 volts or close to that to the oven side of the plug when plugged in , if there is your control board is blown somewhere , this is the most expensive part in the unit because it operates everything. Usally top burners will continue working when this happens unless your model uses the board to cycle them which is rare.
The test will tell you if its the board or the power supply/breaker.
If you have a question let me know and tell me how it works out.
Phil
  • 599 Answers
Generic stove ..no details... only can say yes there are circuit breaking safety involved in its build if it is a modern stove...reset/ fuse /fusable link/ or area near power in that is intended to fail first ... but your short to ground occurred at the element in oven so the break may be near there(cause) as well as at circuit protection power in area... good luck
    Sergeant:
    Novelist:
  • 326 Answers
Yes there is a short tracking occured on the control panel board which needs to checked at all the junctions 1 by 1.
Thermador oven preheat light comes back on during baking session. Oven doesn't stay hot enough to finish cooking food.
Get it repaired from authorised personal. Seems sensor elements has gone down or programming chip is malfuctioning.
Oct 05, 2014 | Thermador Ovens
Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
There may be a fault with the control board.
http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
When the oven is turned on to preheat, the buzzer goes off and an "F1" error message is displayed and the oven turns off. The model # is MGR5750ADW. Is there something we can do to fix it?
An "F1" error code means you have a defective clock assembly (also called ERC- electronic range control). You will need to replace the clock assembly, and they are not cheap, around $200. Hope this helps you, good luck.
Oct 04, 2009 | Maytag Ovens
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
My Kenmore Electric oven quit working.
PUT POOP ON THE WHATYAMACLIT AND SEE WHAT HAPPENS
Dec 28, 2008 | Ovens
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
