Question about Canon Sure Shot Z155 Caption 35mm Point and Shoot Camera
Can't close door after loading film.
X-Mas I took some fantastic pictures with my camera. I had dificulty
in opening the door to unload my film, but finally suceeded. Then when
I reloaded film, I found that the door would not shut. I have worked with it but with no success. I need help!!!
    Problem Solver:
  • 7 Answers
Sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Posted on Feb 15, 2009
SOURCE:
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
I do not know how to load or unload the 35 mm film.
The cartridge will only go in one way. install and pull film to marked line (should have a few notches in the film strip past gear) close camera and either wind until it stops or if batt powered it will load itself then ready to roll
May 23, 2009 | Photography
Loading/ Unloading the Film
anniehongx,
open the film door and charge the shutter. are the drive and take up sprockets turning? if they are then the film was not loaded properly. be sure to push enough film leader into the take up spool bars.
if the spools are not turning then a gear or spring ( advance lever return lock ) is broken.
there are no new parts for the ME Super however some camera repair shops have good used parts that can be used. get an estimate first.
Mar 02, 2009 | Pentax ME Super 35mm SLR Camera
Cbnnot close camera after unloading film
Unless you are sure it is broken, it may not need repair. Have you looked in the manual ? Should repair be necessary, the price will probably be more than the cost of a more up-to-date replacement
Nov 09, 2017 | Canon Sure Shot Z155 Caption 35mm Point...
Film Loading Error
This also happens to Yashicas often. (though instead of stirpping the film, it will rewind it back into the roll. Something's wrong with either the firmware or the drive system. It'll need to be taken to a camera repair shop, or you'll have to send it back to Canon for warranty service, if it's still within warranty.
Dec 04, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Pictures did not take
Check for the settings of the camera .Open the back door of the camera now press the button seeing through back, if the shutter opens up and closes everything is correct.
check for the film.
Apr 01, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Konica Minolta X-370 Wont develop
Two possibilities : 1 ) your film was not properly loaded into the pick up spool and hence it was transported or exposed ; what you took to the lab was unexposed film. 2) the shutter is not opening and again no exposure takes place. To check this open back , set to slow speed like 8th of a second, and see if the shutter opens and closes properly. If the shutter does not open then it will have to go in, unfortunately. Cost ? If it is just an adjustment ( as I suspect is the case ) you should not pay more than $ 100.
Nov 01, 2007 | Minolta X-370S 35mm SLR Camera
Canon Sure Shot Z155 Caption 35mm Point and Shoot Camera Logo
144 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
