SOURCE: need help with my Gold Star microwave.
The owner's manual won;t tell you that, only the repair or service manual.
While we don't have that exact model, we do have the manual for a similar model uploaded here.
A microwave can be dead for many reasons.
It
may be the fuse, which is usually located behind the grille or on the
floor of the oven behind the control panel or between the door switches.
If
the fuse is good, it may be an open thermostat or thermal cutout (TCO)
/ thermal fuse on or near the magnetron or on top of the cavity / body
of the oven.
If it goes dead for a while during or after cooking
then comes back on, the magnetron is probably overheating and causing
the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When
checking thermostats, if it has a hood fan thermostat, that should read
open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If
it goes dead or blows the breaker (or GFI) when you plug it in or open or close
the door, then there's a problem with a door switch or door switch
mount.
If it's intermittent or random, it may be a bad
connection, usually on the control board or a loose fuse holder, or
even an intermittent fuse.
You should do a continuity test on
the fuse while it's in the holder (with the microwave unplugged, of
course) then turn the fuse by hand or take it out and put it back in,
then test it again.
If you remove the fuse, then press the meter
leads against the ends, it can allow internal contact to be made and
make a bad fuse appear to be good.
If you or someone you know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
For
Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat
8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
SOURCE: glass plate not spinning anymore
yes it can be fixed , it is probably the motor that spins it or the circut that controls it
SOURCE: Gold Star Microwave- model MV 1500MG
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
There are many good suggestions for cleaning and deodorizing microwaves here.
i just took out my fuse on the same model. you have to pull down the microwave and take cover off. there should be like 6 screws on backside and cover will slide back and off. then you will see a fuse cover with a small cylinder fuse in a plastic cover. pull it out and check continuity with volt meter. mine unfortunately came up good still, so i dont know what kinda problem mine is having. had a short in light and it popped and power was gone. good luck!!
SOURCE: my gold star microwave worked lastnight. Went to
The outside bottom of your microwave usually has a belt hidden underneath a small cover directly under the turntable. This belt sometimes falls off or breaks, and sometimes the motor that turns the belt fails. Most time the motor can be found if you remove the main top cover of the microwave, about 10 screws.
Parts can be easily found at your local appliance parts store.
Best of luck.
