Question about Dell Dimension 4600 PC Desktop
Replacing the fan or fans in a dell 4600 with the quietest fan I
Where can I find replacement fans for my dell 4600 I want the quietest fans possible I use this computer for recording studio.
    Problem Solver:
  • 9 Answers
Identify each of the fans in the chassis in terms of its square size and thickness, is it 3 wire or 2 wire, confirm its voltage as 12 volt and what current it draws if it tells you on the label. Unfortunately due to the nature of Dell chassis design it its normally difficult to fit anything other than the standard size in the space provided and they mostly use either 80mm or 120mm fans. You than need to look for replacements with the highest airflow in cubic feet per minute (cfm) versus noise (dB). Zalman are normally credited with producing the quietest fans and if you can replace a 80mm with a 120 then you could use a separate speed controller to reduce the speed of the 120mm fan to a slower revs as they by default have a higher cfm (bigger area). This is where the current comes in as 120mm fans generally draw a higher current at full speed but you can normally get away with 1.5 times the stock fan current.
Beyond this requires some serious case mods but the most critical is the CPU fan. If the PSU is the problem them some Dell cases will allow you to fit standard models with bigger temperature controlled fans.
Posted on Jan 10, 2009
    Master:
  • 413 Answers
First you need to tell us which fans are the loud ones you are talking about but normally it is the cpu fan. Any computer parts store should have various fans available for different chipsets.
This link will take you to a page to find a fan. You will probably have to get the model number off your current one to find an exact match
http://www.frozencpu.com/cat/l3/g36/c15/s700/list/p1/Fans-12_Volt_Fans-92mm_x_38mm_Fans-Page1.html
Posted on Jan 09, 2009
Previous fan failure
? I'm not sure what your question is, but replacing the fan on a dell dimension is pretty easy.
Here are the instructions: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1139391
And heres a link to buy one off of amazon: http://www.amazon.com/Dell-K0456-Assembly-Dimension-OptiPlex/dp/B000MME1TW
Dec 30, 2011 | Dell Dimension 4600 PC Desktop
Fan is noisy. Can this be replaced easily
Yes, undo the screws, purchase a replacement fan and reassemble.
damnor01
Feb 05, 2011 | Dell Dimension 4600 PC Desktop
How do you remove the left side panel of the CPU? I need to get to the fan.
You don't really need to remove the left panel. Just follow the instructions listed here to replace the fan units.
Aug 24, 2010 | Dell Dimension 4600 PC Desktop
Card fan makes noise
Turn off your computer, if your familiar on how to open-up you CPU do so, then,
Try cleaning the fan.
What you can do is clean it with a bush (ex. paint brush-a clean one) or a clean cloth.
you can also try to remove the fan then at the center of the fan there's a sticker, you can safely peel it off then you will see the center of the fan, you can apply machine oil on it, then put the sticker back. Then turn on your computer, let's see if you still has the problem :)
Mar 01, 2010 | Dell Dimension 4600 PC Desktop
4600 Sluggish Boot Up
sounds to me like a failing psu, you may need to test it with a psu tester if you have one available, if not any local pc repair shop should have one
Oct 31, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 Cpu Fan replacement help
I know that there are many of these types of system boards out there, What I would do is contact Tiger Direct either in Canada at www.tigerdirect.ca or in the US at www.tigerdirect.com and send the sales team an email sales@tiger.com - They will usually find anything that you need and have very quick and reasonable shipping rates.
Give that a try and see if it works for you.
May 26, 2009 | Dell Dimension 4600 PC Desktop
What diameter is the processor fan?
its not a standard diameter for a pentium4, ime not sure of the diameter as dell does not list it and the actual fan is on the case , ported to the pentium4 cpu covered with a heat sinc. Your best bet is to physically measure it or take it with you when you buy a new fan. If you have the outside dimentions ,the correct screw hole pattern and it fits under the plastic shroud, you have the correct fan..
May 23, 2009 | Dell Dimension 4600 PC Desktop
Replacing the fan or fans in a dell 4600 with the quietest fan I?
there really is no difference when it comes to the fans.... they all create the same noise level...
Jan 07, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
1,307 people viewed this question
Alun Cox
