Question about Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax
Unable to receive faxes
Fax line will ring, but no fax comes through- anyone know what could be wrong?
    President:
  • Gestetner Master
  • 990 Answers
Hello sir; Make sure the cable you plug in right jack, or change phone cable.
Posted on Jan 07, 2009
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Fax not picking up Brother 4100
have you see the display if it was saying the word receiving...?
let me know..
Jun 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Unable to send and receive fax from hp 3050 series
check the phone line is properly connected and you are getting dial tone and dialing facility from the phone line which is connectd to fax line.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 29, 2010 | HP Color LaserJet 3500 Printer
Fax machine will not receive a fax
try switching the fax with a phone and calling... that phone with your cell... see if you have static... if you have static on the line... then call your phone company and have them fix the line... or try putting a magnet filter on the line... next reconnect your fax and call... if your phone line is ok... and it just keeps ringing.... adjust the ring wait time to 2.... if thats doesn't help... you have a bad mainboard...
Dec 10, 2009 | Brother IntelliFax-2820 Laser Fax
I used to have a brother fax machine that received faxes when it detected a fax signal when my telephone's answering machine turned on. I tried all different settings with my Canon MX700 but it still won't...
Issue: Unable to receive faxes with an answering machine on the same line
Solution: Reduce the number of times the answering machine will ring before it answers the call (perhaps 3 rings max.)
An incoming fax may "hang up" if it takes too long for the machine to answer.
Dec 04, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Fax not sending or receiving
hear fax can send but fax is recevieing so what is the solution
Jan 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Same fax and phone number
check the setting in the receive mode button. set it to fax
Mar 29, 2008 | Canon FAX-JX200
Fax answer machine
FAX RECEPTION THROUGH AN ANSWERING MACHINE:
This mode is recommended for a shared fax and telephone line.
To receive a fax if your All-In-One is connected to an answering machine:
On the control panel, press Fax.
Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
To change this setting on the All-In-One:
Press Options until Number of rings appears.
Press the right arrow (+) until After 5 rings appears.
Press Select.
Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
If a fax is not detected, the answering machine completes the call.
Feb 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Gestetner DSm515pfd Digital Copier - Printer - Scanner - Fax Logo
53 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
