Question about Asko T781 Electric Dryer
Asko T781 Electric Dryer Doesn't Turn On
Ok, so our Asko T781 Electric Dryer decided to die on us today. last night, mom said it was working fine but this morning, when she opened it to see if our load is finished, there was condensation in the dryer and the operating buttons didn't light up any more. I checked and re-do the plug-in thing, and it's fine. The on/off button doesnt work. Please help!! :(
  • 175 Answers
Have you reset the cut out on the back? its a little black button that you push in until it clicks. If it does not click, then it probably wasnt the problem. The next most likely cause is a melted fuse holder inside the box on the rear where the power cord goes in. There is a bypass kit available to repair this problem from ASKO, as the fuses are not needed. If you are able to do some simple wiring, you can do this. Otherwise find an AUTHORIZED asko servicer and they will know what I'm talking about. Good luck!
Posted on Jun 18, 2007
    Problem Solver:
  • 17 Answers
And if you can reset the machine via the black button, do a thorough search for built up fluff, specially at the front, where the door opens.
Posted on Apr 19, 2014
SOURCE:
The display doesn't work
Asko are not very common in many areas and so not many people can mentally remember what this model looks like.
However, if the display doesn't not work: Try unplugging it for five minutes or just removing the power for that time. See if it resets.
Not sure what 'does not work' means...no light, no response to touch..respond but does not start..???
Give more info if you seriously nee people who are not at the machine to help you.
Oct 16, 2013 | Asko T781 Electric Dryer
The display on our T781 Electric dryer is "dead"
Do I use the USB socket to charge my battery in the S529. it switches on then goes to MSDC mode.
Oct 16, 2013 | Asko T731 Electric Dryer
My dryer is starting to sound noisy
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 23, 2011 | Asko T781 Electric Dryer
Asko 7005 dryer, start capcitor is cracked and has hard goo coming out the side, dryer wouldn't start and stay running, now it won't start at all. Could the capacitor be the problem or do you think...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 17, 2011 | Asko T781 Electric Dryer
Asko dryers
Akso makes "condensing" dryers (Models T721 and T781) that condense the moisture wich then is directed to a drain. The T701 is a vented style dryer so I'm a little confused.
Dec 15, 2009 | Asko T701 Electric Dryer
My dryer is making an increasingly noisy rolling sound when in use. It is an Asko T701 model
sounds like your drum guides or felt thats wore
out or something stuck inside there rubbing
Jun 17, 2009 | Asko T781 Electric Dryer
Disabled neighbor was given an ASKO T780 dryer, but it doesn't heat up. What could the problem be so I might be able to fix it for him?
most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
Jan 15, 2009 | Asko T781 Electric Dryer
ASKO T761
press the black reset button on the back.wash door filter and condensor,then try again hope this helps.
Mar 16, 2008 | Asko T781 Electric Dryer
Asko T781 dryer trips on over temperature
The problem is probably that it is much lint in the fan, and/or in the back of the drum, so the air is unable to cirkulate fast enough. OR it can be that you are overfilling it with laundry.
Nov 25, 2007 | Asko T781 Electric Dryer
Asko T781 Electric Dryer Logo
759 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you an Asko Dryer Expert? Answer questions, earn points and help others
