Question about 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700HG-B router and I've had a problem connecting on a wireless connection. While the wireless card finds the network and connects, it has limited or no connectivity because the router won't assign it an IP address. I've tried to keep the settings on automatic and also have put them in manually, but to no avail. I made sure the SSID and network key were entered and correct. I've also tried updating the drivers on the wireless card. From my experience it isn't usually this difficult to connect. Can you suggest ways to help me?
  • MISSKITYANDM Jan 10, 2009
    I HAVE THE AT&T GATEWAY AND I WAS ABLE TO GET ONLINE WITH MY LAPTOP 1 TIME ONLY IT WORKS FINE ON THE DESKTOP PC BUT IT TELLS ME I HAVE LOW OR NO CONNECTION AND I HAVE ALL BUT GAVE UP AFTER 100'S OF HOURS TRYING TO FIX IT AND GETTING HELP FROM AT*T IS LIKE PULLING TEETH
    PLEASE HELP ME SOMEBODY PLEASE!!!!!!!!
  • Anonymous Feb 24, 2009
    Is the AT&T 2Wire incapable of assigning?What kind of wireless router just sits there like a brick while computers are repeatedly attempting to gte assigned.Is there a setting on this thing that is messed up?I am tempted to just make the thing wide open but sure as I do that every weirdo,sneak thief,pervert,nazi is gonna hop on my wide open connection and get me a visit from the Police State Goon Squad.
  • 174 Answers
The 2wire is setup with a default network key. Change the network key on the 2wire to another key or type in what you think the default network key is on the 2wire.
Posted on Jan 22, 2009
Where do I find the network key for my 2wire 2701HG-B router?
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 04, 2010 | 2wire 2700HG-B Router (2700HGB)
How do I connect to XBox live w/ ATT 2Wire?
to connect your xbox live wireless to 2wire gateway router you need to go to your xbox menu and click on settings then click A on joystick.Go to network settings then select ip address configure automatic ip. DNS should also be automatic. Under advance tab you'll see wireless you need to click connect.if you are prompt to wype encryption its the 10 digit number enclosed in a bracket on the buttom of 2wire router go to
Aug 19, 2009 | 2wire 2700HG-B Router (2700HGB)
I don't know how to configure my 2wire 2700HG-B wireless, I need to connect my ipod. can someone help me to set them up?
hi there, first is you need to know the wireless settings of the 2wire first, the channel, SSID and the encryption.
once wireless settings are verified then you may try to go to the IPOD, go to settings/wi-fi/ then choose the network there/ try to connect to your network/if it will ask you for a network key, input that as well/ try to connect and you should be connected now.
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Won't assign IP address
Try tuning the router off and back on and do the same with the computer.
Jan 07, 2009 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire router from AT&T, all lights are green, except the "wireless" light. It's not on, how do I become wireless?????
Hi dilex
The 2wire router wireless light comes only when a system is connected to it wireless.
Please post the system that you are using and also what exactly when you try to connect via wireless.
Thank you
Rakesh
Dell Laptop Expert
Jan 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b wireless router
Hi, you will need a ethernet card in the pc to connect up a wireless router, most dont work with usb,
otherwise you would need a wireless adapter.
once you do get it connected, go into internet explorer and type in the ip adress for the router, will then come up with a menu for you to programme in your broadband details, once you get the router up and going, go into the PS3 settings, network settings, it will pick up the router all you need to do is enter the network key and its all go from there.,
ethernet card should cost you about £10 from any shop
Happy New Year
John
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b
Just run an ethernet cable from the back of the PS3 to the back of the router
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
345 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
