Question about GE Refrigerators
Metal ice maker arm is stuck midway. Will not produce ice
The small metal arm that raises as the ice fills in my GE side by side with water and ice in the door is stuck. Will go all the way up but only half way down. No other obvious issues. Have felt inside the little tray to be sure nothing was jammed or frozen. Cannot really "see" as well as I'd like as there is only a narrow space between the ice maker and wall of the freezer.
The small metal arm that raises as the ice fills in my GE side by side with water and ice in the door is stuck. Will go all the way up but only half way down. No other obvious issues. Have felt inside the little tray to be sure nothing was jammed or frozen.I need help !!
Posted on Oct 20, 2010
Kenmore icemaker model 795.7102 not producing ice
is the metal arm in the lowered position or raised?.. needs to be down..
Feb 02, 2014 | Kenmore Refrigerators
Sub Zero model 632 Icemaker shutoff arm stuck in the up position. No water in ice tray. Tried turning frig off for 30 seconds, no luck. Checked water supply, it's good. Metal fill tube not...
The shut off arm is in up position. This is the off position for the ice make. Try pulling the down to the first level this will engage the micro switch to start the ice maker. Also, behind the ice maker is a 4 wire plug remove the plug and see if there were some electrical arcing. But first before removing the ice make plug--Please unplug the refrigerator first before work on the ice maker. stewbison
Aug 20, 2011 | Sub-Zero 632 / S
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
Ice maker on GE refrigerator model TBX21C1 BRRWW will not stop making ice cubes even when the shut off arm is in the raise position
You have a stuck micro switch in the ice maker. Try taking out the maker and remove the metal plate 4 screws and you will see the switch that work on a cam rod. I believe you will find your problem. BB
Dec 15, 2009 | GE Refrigerators
Ice maker is not producing ice. Replaced the water filter
  1. It may be turned off. Check the Ice maker shutoff arm located at the top of the ice bin. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, simply lower the wire.
  2. Is there water in the ice cube tray? If not check for water to the water valve. If you have water then it could be either a failed fill valve or ice maker control module is not activating the water valve.
  3. Check for pinched water supply line (behind the fridge)
  4. Do you have an inline water filter? If so, when was it changed last? To test if it is plugged, check for water both before and after the filter system.
  5. Sometimes the water inlet tube that directs water into the ice cube tray freezes over; this can often be thawed out by simply using a hair blow dryer and warming the area (be careful not to overheat the plastics as they can warp or crack). Then adjust the freezer to a slightly warmer setting and make sure water is not constantly dripping from the inlet tube, as it will only freeze over again.
  6. If it continues to drip we may need to replace the water control valve.
  7. The ice maker head assembly may have broken parts. Look to see if the gears are broken.
  8. Check to see if the small plastic arms that rest against the ice rake are broken.
  9. If the ice maker head assembly is modular and you've found broken parts,
Nov 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stop making ice, water is still coming our of water spo
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
  • Thanks! mannu_rakesh
Aug 24, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE icemaker is not working
*It could be the water inlet valve.
* It could be the water fill spout in freezer could be plugged with ice. this can be thawed with warm water or a hair dryer.
Hope this helps.
Aug 14, 2009 | GE Refrigerators
Ice maker not working
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge and Freezer quit working
May 30, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
