Question about Palm Treo 755p Smartphone
Treo 755 - can only hear sounds through headphone
On an inconsistent basis, I cannot hear calls through the usual method or through speakerphone after I unplug a headphone set.
  • 3 more comments
  • Anonymous Jan 31, 2009
    I am on my second 755P. Both phones have had this same issue with the head phone jack being defective. Other than that, a great phone. Off to Verizon in the morning.
  • Anonymous Mar 06, 2009
    Same problem. Although yesterday I wasn't able to to hear through it at all. Didn't use the headphone but now the speakerphone and earpiece are off.
  • Anonymous Mar 13, 2009
    after removing headphone jack, the phone no longer works without the headphone jack being plugged in
  • Anonymous Mar 26, 2009
    have a treo 755p, thinks it has a headphone set plugged in on a inconsistant bases. Had a suggestion to delete any blutooth device. seems to work so far.
  • Anonymous Apr 09, 2009
    I have had the same problem w/ my 755p and alltel. Palm nor alltel is able to help now that it's out of warranty.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
You need to take your phone to a cell phone repair center and have them replace the headphone jack. The contacts aren't reclosing. If you found this helpful, please post as such. If you take it to the service center, please post this as fixya. TY
Posted on Jan 15, 2009
I cannot hear calls but they can hear me
Not much to tell you other than putting the factory software back on it. Thats the chance you take when you flash any phone.
Sep 21, 2009 | Palm Treo 500 Centro
Can make outgoing calls, but I cannot hear anything. On speakerphone I can hear them, but they cant hear me
its hardware fault.your speaker is not working.try to disassemble the phone,check the speaker interface if there is a corrossion,clean the interface and assemble your phone again.try to make a call.if still not working replace your speaker.
Jul 19, 2009 | Palm Treo 500 Centro
On my treo the speaker icon is missing. I can not take or make calls...no one can hear me
On my treo 755p the speaker icon is missing. I can not take or make calls...no one can hear me.What can i do to fix it?
Feb 23, 2009 | Palm Treo 755p Smartphone
Treo 755 attachments
Problem solved. I called Sprint technical support and they walked me through the process of deleting some corrupted files.
Nov 04, 2008 | Computers & Internet
Palm treo centro.
I had a frustrating problem, maybe the same.. No sound in or out of the phone, no "Speakerphone" or headset icons showing up on the "dialing" screen. after much frustration, hard and soft resets, etc. it turned out that an annoying and unwanted "voice dial" program had turned itself on and was screwing things up. I had to set it to "Never" use voice dial, now all is back to normal.
Oct 16, 2008 | Palm Treo 500 Centro
Treo 680 , phone calls, person i call cant hear me. i have to pull out battery and then it works. help
Sounds like you have a short in your phone and by removing the battery this is somehow triggering that short to connect. This will likely require you to get the phone serviced. There is a fee for this usually if you don't have some type of protection on the phone. If you do it should be as simple as them replacing the speakerphone part of the device. Hope this helps.
Aug 19, 2008 | Cell Phones
Treo 755
Did you ever figure this out? Mine is doing the exact same thing now.
Aug 01, 2008 | Palm Treo 755p Smartphone
Treo 755 not able to make calls
The only workarounds I've read about these issues is:
1. Plug in the headset again and pull it out crisply and see if that works. Another method I heard, is to stick a toothpick in there.
2. Using the OEM Treo mono headset, insert the jack fully into the socket, spin the jack in the socket 180-360 degrees and remove the jack with a quick jerk. If the socket is truly undamaged, this technique, often repeated, seems to enable the speaker.
3. Some report that the headphone jack adapters, 3.5 to 2.5mm, work for this as well, that has NOT been my experience.
4. VolumeCarePro will bypass the headset switch and is a software workaround.
5. Otherwise, the only way I've been able to 'resurrect' the speaker is by hard reset, and once it took two hard resets.
As a result, I do not use my headset jack on my Treo 755p at all any more.
Unfortunately, this is an area that Palm is aware of, but has done little to fix.
is a hard reset
Jan 27, 2008 | Palm Treo 755p Smartphone
Palm treo 650
The 650 seems to have a delicate headphone/mic jack. Dropping the phone, even gently, seems mess up that jack. I returned my first treo 650 as defective, and got a new one. The same thing happened to my new 650 after I simply compressed the phone in my breast coat pocket by holding my mail against my chest.
I can't get a new one because the replacement treo comes with no warranty of any kind. :(
My advice would be to find a PDA/phone repair service to repair the jack or diagnose the problem if it turns out not to be the jack.
Jan 12, 2008 | Palm Treo 650 Handheld
Palm Treo 755p Smartphone Logo
148 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
