Question about GPX MW3837 MP3 Player
Switching from MTP to USB
I am not able to sync my device to my computer. It did allow me to sync one CD to the MP3 Player when it was in USB mode.
Now it's stuck in MTP. Can it be switched back in any way other than pushing the USB/MTP button? I push the button and nothing happens.
How do I get the device to sync to the computer? It keeps saying there was an error so my device may not copy properly.
  • Anonymous Jan 09, 2009
    when you plug in the mp3 it doesnt load up the players menu
It does not need 2 inless you got an old PC
Posted on Jan 07, 2009
I need driver called mtp usb device for my c2-03 mobile
Many devices use Microsoft's Media Transfer Protocol to synchronize with computers. Unlike standard USB mass storage devices, MTP devices don't behave like USB flash drives. Windows Media Player includes built-in support for MTP devices and can synchronize media files to and from them. You can download MP3s to your portable music player, cellphone or other MTP device using Windows Media Player's sync feature. The device appears in Windows Media Player when you connect it to your computer.
Read more: How to Download a MP3 to MTP ' eHow.com http://www.ehow.com/how_12186594_download-mp3-mtp.html#ixzz1wFmzrcvt
May 29, 2012 | Nokia C203
Enter usb2.0 msd mode - pls help
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode.... make sure your usb 2.0 driver is installed....... Connect to the mother board.. MSC is best create a music1 folder and put music in there then there is no switching back and forth to mtp ms....MSC can sync the player and the expansion card
Dec 19, 2010 | SanDisk Sansa e260 MP3 Player
My Sansa e260 player works fine, plays my music and everything, but I have a problem with adding/deleting music. When I connected it to my computer, it did not recognize the player and it did not show up...
MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion..... make sure your usb 2.0 driver is installed..Syncing to wmplayer puts music in the mtp music folder. change usb modes again and use the explorer to see the sansa msc lets you sync any Q/A IM or email me @ Schmead01@yahoo.com
Jun 23, 2010 | SanDisk Sansa e260 MP3 Player
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Try and reset the player.
Reset the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Then try this
Connect the player to your computer.
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
<<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager
1. Right-click My Computer, and select -- > Manage.
Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
*** See This Tip Posted here ****
Solve your MP3 Player Connection Problem.
The Sansa player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
>>>> BUT TRY THIS <<<<<<<
Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 was on but now it won't come back on or charge.
Reset the player:
Then try this
- If the player does not turn on try other USB ports2_bing.gif or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub2_bing.gif.
If you receive the error "USB Device2_bing.gif Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS2_bing.gif.
Refresh the drivers
Feb 21, 2010 | SanDisk Sansa Clip MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer.
3. When connected the LCD Display will either say “USB” or “MTP”.
4. Press the “M” (mode) button to switch between “USB” and “MTP” mode.
“MTP” mode will only work, when your player is connected to Microsoft
® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
8. Repeat steps 4-7 for any other items that you want to copy to your unit.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
I can't sync my music list to gpx mp3 player
On the mp3 player, switch between the Usb and Mtp mode (The M button) on the side of the player.
Jan 21, 2009 | GPX MW3837 MP3 Player
Mp3 player keeps getting SYNC notice
For NS-DA1G and NS-DA2G: If you are receiving a SYNC notice, your DRM media license has expired. If you are using a media manager like Best Buy Digital Media Store or Windows Media Player. you will first need to authorize the player as an MTP device (device authorized to play Digital Rights Management song files) and then re-acquire the licenses for the tracks. There should be a button that allows this function in your media software.
If you want to remove your DRM tracks, got to:
MENU - Settings - USB - File & Folder
This puts your player into Mass Storage Mode. Once in this mode the player will act like a USB drive and you can navigate to and delete your unwanted files.
Dec 04, 2007 | Insignia NS-DA1G MP3 Player
GPX MW3837 trouble synchronizing
If you get the MTP on your screen and your trying to sync it with your computer just press and hold the usb/mtp button and your computer will reconize it [=
Nov 26, 2007 | GPX MW3837 MP3 Player
184 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
