No sound from my sophia 21 inch panasonic tv
I bought the tv in 1998 its in good condition the picture quality is perfect onlty problen is no sound coming out from tv speakers
  • nadeemshouka Feb 28, 2009
    i bought the tv panasonic Tv Model No.Is Sophia -TC-21,S-72 its in good condition the picture quality is perfect my problem is last year tv yok is damaged now in market yok is not availabe so you requested where i can puchaseyok i am delhi please help me
5 Suggested Answers
cyberclash
  • 6 Answers
SOURCE: Sound missing
helo try to short the spider transistor along ic amplifier. it is in a mute
Posted on Jun 25, 2007
jingjao
  • 252 Answers
SOURCE: No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Posted on Jul 04, 2009
SOURCE: RCA Guide Plus Gold Gemstar 27 inch Entertainment
how do I hook up a wii to my 27 inch rca guidegold gemstar plus. I use the inputs on the rear and can't get the tv to recognize them.
Posted on Jan 01, 2011
SOURCE: panasonic tv old model
Panasonic 12 year old TV is making a clicking sound, when I turn it on, manually. The remote control cannot turn on or off TV, nor can I get any channels at all. What could be the problem?
Posted on May 04, 2011
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
BLURRED PICTURE AT THE BEGINNING WHICH GETS CLEAR AFTER A FEW HOURS
Check and replace the back-light inverter board. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 24, 2014 | Panasonic Flat Screen 21 Inch Multisystem...
My 21 inches lg tv produces sound but a very dark
Check resistors in the small PCB connected to picture tube. Check picture tube grid voltages. Check brightness control swing on the IC out put. Note down the IC no and search in the Google for pin configuration.
Jul 06, 2010 | Televison & Video
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Standard 21 inch tv approximately seven years old. Picture is perfect but the audio is not working. When taping from the tv the sound does come through, but sound cannot be heard in the room. The mute...
Sounds like there's a bad solder connection on it, maybe on the audio amp i.c. If you have some experience in electronics it would be easy fix. The audio i.c will be located near the plug that connects to the speakers is, it will probably start with tda#### or la####.
Sep 23, 2008 | Panasonic Televison & Video
Poor picture quality and sound problems on Lite-on LVW 5115GHC
have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Aug 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Picture brarred, focus responding but cant improve picture quality
did u try adjusting the focus knob in the flyback transformer? this device is connected to the anode of the picture tube which produces the high voltage so be very careful of adjusting it. dont touch the wire linking to the tube. thats approximately more than 21,ooo volts dc! good luck!
Jan 17, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
Electro Med Services...
