Question about Mitsubishi CK-31304 TV
Mitsubishi 31" standard screen tv
I have a problem with a 31" Mitsubishi tv, it has great picture except it appears to be pulling in at the top right corner when picture changes, not consistant, mostly when going from light to darker and when changing channels, any ideas?
5 Suggested Answers
  • 10 Answers
SOURCE: Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Posted on Sep 27, 2006
  • 1284 Answers
SOURCE: Black box in the middle of the screen
To be exact it is in the TEXT mode within the Closed Caption menus.
Posted on Feb 18, 2007
  • 16 Answers
SOURCE: Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
Posted on Jan 20, 2009
  • 252 Answers
SOURCE: black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Posted on Jan 26, 2009
  • 377 Answers
SOURCE: I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Posted on Jun 04, 2009
0 characters
1 Points
Where can I find a Mitsubishi CS-35305? Mine just lost its picture (bought in 1995) and I love this set. Any direction would be greatly appreciated. Thanks and God Bless.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Type in the brand name and type (TV, VCR, DVD player etc:) of your device, in the search box [at the top right] of the home page. It will make surf easy.
Jun 30, 2015 | Mitsubishi Standard (CRT) Televisions
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
Mitsubishi WS-55807, screen removal / cleaning
Hi, thank you for visit fixya.
Pull out the speaker cover ( slow toward your self).
You will see screws in the middle , take it out ( maybe is 4 o 6 screws), be careful with any wires connect to panel control. Disconnect any connector to panel control. Pull toward your self , slow and slide up . Use a fine brush for best result, use glass cleaner liquid.
Any question, I will be here.
If you need additional help, please send me a picture front tv and I will show the right process.
Thank you
Dec 05, 2009 | Mitsubishi WS-55807 TV
C 03 on screen
call tech support
Mar 11, 2008 | Sanyo DS31590 31" TV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
Sep 08, 2007 | Mitsubishi WS-65819 TV
Jvc model av36230
you know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
May 16, 2007 | JVC AV-36320 36" TV
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Bowlike effect convergence all screwwed up
I suspect you originally had an intermittent solder connection on the convergence circuit board. This may have damaged the convergence IC's on that board by now if repairing those connections doesn't fix the set.
Mar 10, 2007 | Mitsubishi WS-65819 TV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Standard (CRT) Televisions Logo
24 people viewed this question
Top Mitsubishi Standard (CRT) Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Standard (CRT) Television Expert? Answer questions, earn points and help others
