Question about PANDIGITAL (DPF802) Digital Picture Frame
Unable to load more than ~50MB into df780 digital picture frame
When I try to load pictures from my computer into the internal memory it will take about 50MB then give an error message unable to create file even though the internal memory should hold 512 MB. when I check the memory it indicate tere is 450MB free
  • mrsk130 Jan 08, 2009
    I reformated the internal memory in FAT32 and the problem is solved. Able to load 487 MB
  • Elizabeth Dec 30, 2012
    Thanks for the tip! I was stuck with messages that the disk was full even though I saw I had more than 100 mb empty. I created a folder called "all photos" and moved all the jpegs into there -- now I'm able to add many more files! Really, thanks for posting this solution! I never would have come up with it on my own, and I hate being bested by my technology!
    Problem Solver:
I had the same problem on a 128 mb memory. I figured out that it can only load a certain # of objects/files. So I started from scratch, and I created a new folder in the pandigital and copied all the files/photos/mp3's into that 1 folder. Thus 1 object. I was able to fill the entire capacity after that. I can't believe I actually helped solve one! I hope it works for you...
Posted on Jan 10, 2009
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
How do I upload photos from my computer to the picture frame? The frame says PC Connection established. Remote is temporarily inoperative.
does the picture frame have an internal memory or accepts a memory card?
if memory card is accepted then try uploading images to the memory card and then inserting the memory card into the picture frame.
i hope this was helpful.
Dec 12, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
How do I copy pictures from a USB port to the memory in the Digital Picture frame?
it depends on your digital frame becuase some frame cannot be save the picture on the internal memory. if the manual says that you can save or upload try to go setting and look for copy then choose from( memory card to internal or internal to memory card)
goodluck my friend
Jul 13, 2010 | Smart Parts Digital Picture Frame
The SanDisk shows all of my pictures when I call them up on my computer but I put the chip in the digital picture frame and it won't load them.
You have to go to menu and select exteranl media,
or
You can go to the menu and load external pics to internal memory.
fred
Dec 21, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Can't load more pics to internal memory,past about 100 photos
Your jpg files(pics) may be too large.
reduce them (i use 800x600.)
Irfanview is a good resize pgm(free)
fred
Dec 11, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
I am unable to copy pictures from my blackberry to the internal memory. I receive the message that the "disk is full"; I believe the frame will hold 1000 pics; I'm only copying 130. Please advise
There is no internal memory on this particular model. Therefor the problem must be with the SD card. Pls exchange the card and the issue should be resolved.
Nov 26, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I need instructions on how to load pics to my Optimus 07A08 digital frame.
On the back of the frame remove the memory card, then You need to use a pc with a Memory card reader, you can get usb card readers that simply plug in your usb, then copy all the pictures you want on the card from pc.
Oct 29, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a compact flash card in my digital camera and I am not sure how to load specific photos onto the DBF-0802. I do not want to damage the card before I start. Abd also, how do I load images that I...
The digital frame only has 8mb of Internal memory, And if you’re using a high-resolution camera that means you’re only going to get a few pictures loaded into the internal memory. You would be a lot better off playing your pictures directly from the CompactFlash card. Once you place a flash card into the frame it automatically should go into a slide presentation mode and then you should do is hit play.As far as loading it from your computer you need to get a mini USB cord and connect that to the computer and the frame. Once the computer recognizes the frame you can do the transfer.
Oct 17, 2017 | Westinghouse DPF-0802 Digital Picture...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Coby DP-887 Digital Picture Frame: Unable to transfer pictures to internal memory
The Coby DP-887 does not have built in memory so one cannot "load" pictures onto it. It is a viewer in every sense of the word. If you load pictures on a flash drive or memoory stick and plug that into the Coby DP-887 then you'll be able to view pictures or video.
Dec 22, 2007 | Electronics - Others
PANDIGITAL (DPF802) Digital Picture Frame Logo
243 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
