Question about Philips 32PT6441/37 32" TV
TV PROBLEM philips tv, model 21pt3324/79 keeps on shorting (short circuit) the line output transister (bu11 af), and then the set starts to give a squeking sound, what could be the cause?
After replacing the shorted Line driver Transistor, carefully removing and replacing the same CRT base circuit, resulted with the problem going away. I cannot say what really was the cause, but I suspect that there could have been some form of acing on the neck of the tube.
Posted on Jun 01, 2007
    Problem Solver:
  • 10 Answers
This could be caused by 1 of 2 things, firstly the crt could be arcing, check this by taking the tube base away from the tube neck (only do this if you are a qualified engineer, high voltage and all that), secondly your F.B.T. (Fly-Back Transformer) could be up the swanny (faulty). It would be handy to know if the transistor blows instantly. Hope this is of some help to you, please email me if you require anymore assistance neilandrach123@hotmail.co.uk
Posted on May 31, 2007
My sansui tv have a problem.transister 4460 getting short after replace output voltage drop stand by realese
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 30, 2014 | Televison & Video
Philips md#32PT9100D/37 will not turn on only
Hi
Your tv set may have a short circuit both in the power supply and horizontal output stage. The first approach I suggest is to check the rectifier fast diode in the line supply (90/100V) for short. This model is prone to burn this component and may be associated with some problem in the horizontal output or even in the RGB output.
I would like to point out that this task require a technician as should be supported with a schematic of this model.
If this is helpful, I shall be glad.
Sully
Sep 22, 2013 | Philips Televison & Video
Tv horezantal transister hot
Check for any short circuit at the horizontal output section circuit. Check all the non-electrolytic capacitors used there. Replace all suspected ones with same capacitance value. A winding short in the windings of deflection yoke, will too make the horizontal output transistor to get overheated. If so, there is no other way than replace the deflection yoke. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 11, 2013 | Televison & Video
Philips 42pf7321d 37
The line output section circuit works as soon as you switch ON the TV, and then come across any short circuit inside the set, and shuts off. That is happening here now. You must check the set, and trace out this shorted or damaged component/s. If you're sound in electronics, download the repair manual to this model set by internet, and carry on. If you're not sound in electronics, contact any service technician. If you wish to get some details about repair work, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 27, 2013 | Televison & Video
No power ticking sound when plug into outlet
Hello
Your Philips Tvs line output section has some trouble with it. All philips power supply circuits are so designed that, even a small short circuit in the ciruit board occurs, the power regulator will sense it, and the entire system will shut down, and that is happening now in your TV.
You just start with the horizontal output transistor, fitted very close to Line Output Transformer [LOT], for any short. You must desolder it out from the circuit for this check, and check it for collector to emitter leak. If this will happen, the main regulated power supply ie 120VDC, will gets shorted through this transistor, cause a dead short circuit. If it is shorted, you must find out the reason for that short.
If LOT said above has damaged, this transitor will also get shorted. In otherwords, if LOT is damaged, its driver transitor,will also will get leaky. You just replace this transitor with an identical one. Switch on the tv for a while, say 10 seconds or so, check its heat effect. If it heats up abnormally, surely LOT has damaged, and you should replace it also with an identical type and number. Ok
Nov 24, 2010 | Philips 32PT563S 32" TV
Chopper transister blown fuse blown
100k ground from ic pin replece 3 electrolytic cap . Adjust preset for 95v if it isphilips tv
Aug 17, 2009 | Televison & Video
Tv dead
please check flyback transformer for short
good luck
Nov 01, 2007 | Televison & Video
No power
Check horizontal output transister short. Check AC fuse open. If it is open check powersupply section any short circuit and check PTC.
Sep 09, 2007 | Fujitsu Plasmavision 42" TV
Sony KV-32HS510, worked perfect, turned on the next day and all I gat is flashing red light.
Your tv does not need a reset,what happened something went bad inside the set and it needs to be replaced,if you are familiar with tv service you can start by checking the horizontal output transistor for a short,if he went bad it likely made the fuse or safety resistor open.If you are not too familiar with tv service be safe and call for assistance froma servicer.If you decide to go in looking for problems make sure the set is not plug in.Let Us know how it goes or if you need more information.
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Philips 32PT6441/37 32" TV Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
