Question about Imperial ICV-1-H Turbo-Flow Electric Single Oven
Melting fenwall starter sytem
I had 3 fenwall starter system instaaled and they all melted. I have spoken to imperial and they told me it might be the gas regulater . I beleive that in New York city all gas is regulate by the city. Do you have information about or any solution. thanks a concerned chef
  • 24 Answers
You need a gas engineer to verify that the regulator on the back of the unit is correctly adjusted. The incoming gas might be regulated to one pressure, but the oven works on a special pressure, controlled by the machine regulator. Also there is a small cooling fan in the control panel that keeps it all cool. The wiring can become detached or the fan fail if the control panel has been withdrawn harshly
Posted on Apr 03, 2014
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
The temperature suddenly elevates, and the metal melts
WoW, the metal MELTS!,,what metel is it that melts ?
May 05, 2011 | Ovens
Our kitchen uses the Imperial IVC-1 after it reaches temp it cuts off and inttermitently will not fire again unless it is turned off then back on. what in going on
Not sure if you have electronic or mechanical thermostat. However problem is likely to be in the electronic ignition sequence box (Usually a Fenwall) Also check the panel cooling fan is working, it cools the Fenwall box.
Feb 02, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
My wife put foil (alum)on bottom of new oven , foil melted in and ruined finish ... im over that , now she wants to know if its dangerous to eat food cooked in said oven
i would say you are ok,but the thing that consernes me is what was the temp that melted the foil in the first place,its takes a lot of temp to melt foil and i mean over 800 degree,was this over a long period?yes it is safe to eat the food but get that oven checked?rate this answer.adrian,,,,,,,,,,,,
Aug 22, 2010 | Ovens
Terminal Block
terminal was loose started arcing like a welder causing heat to melt the block
Apr 09, 2010 | Ovens
Oven knobs melted. should this have happened?
you may check the unit if it came with a shield for the knobs to protect them from melting usually it has a shield to avoid the knobs from melting.
Apr 06, 2010 | Electrolux Ovens
Ice cubs ar melting GE double door frig what can be the problem?
If the ice cubes are the only thing melting it could be the heater in the ice maker which thaws the ice a little to release it from the mold.
If other things start melting it could be auto deforst failure indicated by iceing of the evaporator coils behind the rear cover in the freezer.
Aug 29, 2009 | Ovens
My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
It is one unit. You can not replace just a microwave.
Dec 01, 2008 | Ovens
Imperial ICV-1-H Turbo-Flow Electric Single Oven Logo
80 people viewed this question
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
John Rodgers
John Rodgers
Are you an Imperial Oven Expert? Answer questions, earn points and help others
