Question about HP LaserJet 3330 All-In-One Printer
Can't fax - cancel light keeps flashing
Says to power it off & back on. tried this several times with no luck
  • Anthony Lam May 11, 2010
    Does the control panel display error message " Scanner error power off/ on"?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
The on button keeps flashing and the red light stays on
Try resetting your Canon PIXMA. Here's how:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Have a good evening!
Jan 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ultra Wash Diswasher & light is flashing on pot & pans and can't remove it. Try canceling it several times
Try unplugging the dishwasher from the power for 15 minutes. This might clear the problem. If it comes back when you plug the unit back in it might be a problem with the control panel or the board.
Sep 22, 2009 | Kenmore Dishwashers
ELTRON 2622 thinking it's a fax
Turn off the printer and place your finger on the green feed button. With the button depressed, turn the printer back on. Let the light flash (ONLY!) four times and release the button. Printer will cycle through 2-3 labels. Press the feed button one more time.
You've just set the printer back to factory default and dumped whatever setting told it to act as a fax.
Aug 07, 2009 | Zebra ELTRON 2622 TT Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
I had to cancel the printing of 26 pgs. so
If you look down on the lower right hand side of your screen (by the time) there will be a couple of icons and an arrow pointing to the left. If you click on the arrow, you should see a little printer. If you click on it with the right button on your mouse a window will pop up. Click (right button again) on
"Open all active printers and faxes". A window will pop up showing the pages that are in the queue. Across the top of the window that pops up click on "Printer" then click on "cancel all documents"
Your problem is that the pages were downloaded into the memory of your printer so they have to be cleared from that memory. Good luck
May 05, 2009 | HP DeskJet 932c InkJet Printer
Philips Laserfax 725 SERVICE [2] ERROR CODE
Service 2 relates to the Fuser unit. It will have to be replaced by an engineer.
Apr 17, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Beko wma 1715 pre wash led keeps flashing manual says contact service engineer
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
All we need now is for the rain to stop
May 04, 2008 | Washing Machines
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
HP LaserJet 3330 All-In-One Printer Logo
Seeker5211
Seeker5211
