Question about Acer Aspire 3000 Notebook
Im using acer aspire3003 wlmi. just bought 250 pata hdd from wd. and it displays 128gb but should 250gb how to resolve this issue.
    Genius:
  • Acer Master
  • 1,102 Answers
Did you make sure it was compatible and would work with your system
you can go into bios setup
try restarting a couple times and see if it picks it up
try control panel add new
and make sure everything in device manager is correct
Posted on Jan 28, 2009
  • DEKR
    DEKR Jan 29, 2009
    I was reading my pc book on memory and it is very possible thta you have too much memory for your system
    how old is the system
  • DEKR
    DEKR Feb 02, 2009
    don't forget to rate me
Hdd 2tb only showing in device & printers
Sounds like you require new drivers for the USB sockets. Only use Acer drivers, Microsoft are not trusted to work without issue.
Acer Explore Beyond Limits
Aug 30, 2016 | Acer Aspire V5-571P-6835 15.6" Touch...
Toshiba satellite pro a60 How can I use a ssd 128gb on this laptop
Exactly the same way as any other hdd. initialise it. Format it and load your OS.
Sep 30, 2015 | Computers & Internet
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
Mar 23, 2011 | Western Digital Scorpio Blue 250GB PATA...
HDD capacity greater than 128GB with Acer Travelmate 2300
ive had a look on the acer website and there is a replacement bios available , but theres no mention if it would enable large Hd support , rather than flashing your bios and potentially destroying your laptop i would purchase a external drive , you can get the enclosures for 10-20 pounds and fit a decent size HD in this
http://www.ebuyer.com/product/159438/show_product_reviews
Nov 09, 2009 | Acer TravelMate 2300 Notebook
I have new wd external hdd 250 gb, its not detecting on my desktop.
Is the drive formatted? Did you get an install disk supplied with it? If so try running it.
Check your system BIOS and see if the drive is being detected there. Also you can check the Device Manager in Windows to see if there any issues with the drive.
Sep 12, 2009 | Western Digital WD Passport 250GB Portable...
250Gb hard drive for Acer travelmate 2300
No. I have tried a 250 Gb but my 2303 wont carry it. it will only recognize up to 130Gb but I did not try it with a 120Gb internally, my 250Gb IDE -HDD will run as an external but there is a power surge warning that comes up when I connect it, however I can run a 500 Gb SATA HDD with out this happening. MURRAY the MAGNIFICENT
Apr 08, 2009 | Acer TravelMate 2300 Notebook
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Mar 25, 2009 | Western Digital WD Passport 250GB Portable...
Intel Desktop Motherboard D850MV
Hi Funky Fish,
If you're WD is an IDE drive please re-check the pin setting on the drive. Please download. Data lifeguard diagnostic software from WD's web site. Use their bootable software to seup you're drive. http://support.wdc.com/download/index.asp?cxml=n
After which you're drive will show the correct size.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 26, 2008 | Intel Motherboard
Trying to format a 500GB HDD at full capacity
check your bios if the disk is recognized as 500gb first. if it is not recognized, update your motherboard bios. most updates are available in their manufacturers site.
Oct 11, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
