Question about iiyama ProLite E380S-S 15" LCD Monitor
Speakers - no volume
The monitor is approx 3 years old and we have recently starting using it again. However there is no sound at all from the inbuilt speakers. Using the buttons on the monitor I have checked that "Mute" is off and Volume is showing at 100%. Can you help please?
  • Anonymous Jan 08, 2008
    no sound is caming from the spekers
    President:
  • 2,961 Answers
Double check that the speaker wire (green) is connected in the back of the monitor and into the back of your pc into the green connection, if it is and there is no sound you can always use a seperate pair of speakers, as it will be cheaper than repairing the monitor.
Posted on May 30, 2007
My packard bell is about seven years old and was fine until i had it fixed recently and was told that i would need to buy new speakers that could plug into the back of the computer as I needed a new...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 25, 2011 | Packard Bell (030069) Sound Card
I have the Pulse 424 speakers and they are like 8 years old. The speaker with the power and volume knob is out. It works to turn on speakers and control volume but no sound. The woofer and the other...
if you are having problems with your sound
also
hope this helps
Mar 31, 2011 | Labtec Pulse 424 Computer Speakers
No sound coming out of my hp monitor speakers. Monitor shows speakers are on and not muted. I have a green cord connected from my monitor to my desktop.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 16, 2011 | HP (PP036AA) Computer Speakers
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
May 24, 2010 | Acer X193W LCD Monitor
Hi, I have a Samsung SyncMaster215tw, I've been using speakers to hear music and movies but recently gave them away, how can i get sound directly from the monitor?
The manual (you can download it here if you need a copy) shows an audio input jack right next to the VGA input connector. This jack takes a 1/8-inch stereo plug the same as the output jack on the computer. You can use the same cable that is usually supplied with computer speakers. Just plug the cable into the computer's sound output jack and the monitor input. I'd recommend setting the volume on the computer to maximum, and using the monitor volume control to adjust your sound.
Apr 01, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
I am thinking of buying a used Hansol 550 - three years old. Do they deteriorate with age ? Do all the old models have speakers fitted ?
3 years old will more likely to need new set of caps, not all monitors come with built-in speakers. See failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
I would not buy a 3 years old 15", save the money for newer and bigger monitor.
Feb 10, 2010 | Hansol H550 15" LCD Monitor
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
Logitech 510ex 5.1 sound expert external - problems
Mr. Mattyal
This not a common problem
Do not use full volume of your system.
Use only 65-85% volume of your system ok.
Then you see problem is solved
Sep 23, 2008 | Logitech Audio Players & Recorders
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
iiyama ProLite E380S-S 15" LCD Monitor Logo
795 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Marvin
Marvin
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
