Question about Maytag MMV5156AAS Microwave Oven
MICROWAVE, NO HEAT, TURNTABLE WORKS, COULD THIS BE A FUSE
MY MICROWAVE, ONLY 4 YEARS OLD, THE HEAT JUST STOPPED WORKING, THE TURNTABLE WORKS FINE, COULD THIS BE A FUSE?
  • 2 more comments
  • Anonymous Feb 18, 2009
    After a loud popping sound, my Maytag stopped heating food. Everything else works, i.e., the turntable, lights, clock. The model number is MMV5156AAQ and it's a 1000W above-the-range oven.
  • judith carrillo Mar 03, 2009
    i have the same problem we have a maytag mmv5156ssa microwave and everything is working but it will not warm up food can we fix this or is it time for another microwave?
  • Anonymous Mar 04, 2009
    I have the same problem. some times it works sometimes it doesn't heat up. I also noticed lights go a little dim when the microwave is started.
  • hfabiano Apr 10, 2009
    al the other functions seem to work, except the microwave will not heat
  • Maytag Master
  • 9,086 Answers
Please reply back with your brand and model number so we can help you.
Posted on Jan 09, 2009
  • William Miller
    William Miller Jan 09, 2009
    (Sorry, I mean my post
    to be a Clarification Request instead of a Solution)
    Please do not rate it until I can provide a solution.
My Sunbeam Microwave SGB8901 lights up and seems to be working, but it doesn't heat anything. Is this fixable?
Only 2 years old? Hopefully you still have owner's manual, troubleshooting section should help you look for the problem. Hopefully, there is a circuit breaker, or perhaps a fuse. I hope it was not used with a metal object accidentally. No help? Check with Sunbeam Customer service, be nice, they usually are helpful.
Mar 04, 2015 | Sunbeam Microwave Ovens
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Sep 29, 2008 | GE JVM2050 Microwave Oven
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Maytag MMV1153AAW microwave
I have the same problem with mine!!! I spent 58 dollars to have a 6 dollar diode replaced. Now 8 months later... same prob. Replaced again myself and working fine again. Just make sure you label the wires while working on it. I didn't and it cost me 2 new fuses! Hope this helps.
Aug 06, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
253 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
