Question about Epson Stylus RX580 InkJet Photo Printer
Ink cartridges wont accept in Epson D120 printer
I have an Epson D120 printer, i have just tried to install some new inks but the printer doesnt seem to want to accept them.
All is what keeps happening is a green and orange light keep flashing.
Can you help
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Epson D120 printer carriage goes to the left and stays there.
Yes I understand that, I think your proilem maybe that there is dirt/ ink on the slide bars. ( Sublimation ink ias notorious for imparting a residue)
So take a cloth and clean those metal rods that the cartridges slide along. They should reveal a lot of dirt on the rag. Then use some wd 40 or light sewing machine oil on another rag and wipe on wipe off. They only need a very slight amount.
I hope that is of help to you.
Please rate my help++++Thanks for using FIXYA
Jun 28, 2010 | Epson Stylus D120 Network Edition ultra...
Does not reconize non epson ink cartridge. I remove and reinstalled and it printed but now its back to not reconize cartridge.
You did not say if you were using "New-Epson Ink Cartridges", or actually using "Non-Epson Ink Cartridges" [Generic or Third-Party ink cartridges] in your printer. I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunatly, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps...Good Luck!
Jun 09, 2010 | Epson CX8400 All-In-One InkJet Printer
I have just changed all the ink's in an Epson d120
If you replaced with "genuine" ink-cartridges, then it should report "full".
If you replaced with "refilled" ink-cartridges, then the company that refilled forgot to "reset" the electronics inside the ink-cartridge, in order to report "full".
Or, perhaps, the software "toolbox" that came with the printer has a button "I have installed new cartridges, please re-verify the ink-levels" ??? Click that button.
Nov 27, 2009 | Epson Stylus D120 Network Edition ultra...
EPSON Stylus CX7400 won't accept ink cartridge
Mine acts up this same way (more often than not). I've found that as I install new cartridges, it helps to "tilt" it towards the chip end so that it "rubs" as it's going in. You'd normally hold both sides when replacing a cartridge but I don't even touch the outer end as I do it & it seems to help the printer "see" the replacement when installed.
Oct 20, 2009 | Epson Office Equipment & Supplies
Hi there, I have an epson d120 that will print but the print is very faded. Can you help? I have put in new inks but still having the problem.
Check nozzle, do head cleaning procedure. Wait for 30 minutes. Check nozzle again. If there are no difference betwen to output of nozzle check, you have to cleaning head manually. Check for it at aicaxz solutiuon.
Oct 18, 2009 | Epson Stylus D120 Network Edition ultra...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson R260 won't use new Epson hi-cap lt cyan cartridge
Please log on to epson.com and get the ink pad reset utility software from there. It runs on win xp and win vista.
Apr 10, 2009 | Epson Stylus Photo R260 InkJet Printer
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Epson Stylus RX580 InkJet Photo Printer Logo
822 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
