Question about Video Game Consoles & Games
My ram is ddr800mhz but it runs 400mhz
Both are 1 gig
and my T-utilty shows them running 400mhz
So plz help me
  • zenigata May 11, 2010
    Is this Prebuilt or white box? Company of the RAM? Maker and Model?(mobo, or complete computer)
    President:
  • 2,976 Answers
Too much malware or junk running in the background. Clean things up and run a good registry cleaner. You will be running at close to top speed after this. You will never hit top speed. There are some things that must use some resources for your computer to work. You might want to increase your RAM too.
Go to belarc.com and download & run the program. It will show you exactly what is in your computer and how it's functioning.
Posted on Jan 18, 2009
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Jetway motherboard 939 GT4-SLI-G will only accept 3.5 gig RAM and not 4 gig RAM as per specifications. It does not run on gaming applications when 4 gig inserted (4 x 1 gig). Any solution?
If you are running a 32 bit version of windows it will only see up to 3.5gig of ram in your system no matter how much ram you put in there.
This is down to 32 bit windows only being able to address a maximum of 3.5 gig of ram.
Windows 64bit can address a far larger amount of ram and is why you will see all windows computers running 4gig or more of ram having Windows 64bit installed.
As you have said your computer is running Windows 7 32bit the only way you will get your computer to see the whole 4gig of ram you have installed is to upgrade to Windows 7 64bit.
Hope this answers your question and helps you out.
Jan 18, 2011 | Jetway 939GT4-SLI-G Motherboard
Need full description of RAM for Gateway 300X CEL
Well, a p4 ddr 266 usually has a cpu limit of 2.4 ghz, 400mhz bus. As for Essex, you can purchase those by looking for them online. As for the ram, ask Gateway the max ram limit (likely 1 gig) at 266mhz bus (pc2100). I did a little research online and I did not see any 300x with more than 1 gig or total ram. Look for 266 bus on your ram, (2x512), and a CPU at no higher than 2.6 at 400mhz bus (2.4 would likely be cheaper and may be more compatible, and you only lose 266 megahertz). Also, do not plan on making this into an uber-sweet gaming system. It was designed for basic computing. You can max the ram at a gig, drop a p4 2.4 in it, and add an add-in video card to beef up the graphics. You can play world of warcraft on it, but your framerates will be about 15-25 fps, and you can watch movies and shows, but you wont be impressed. Still, it makes for a great office machine, or drop a big fat EIDE hard drive in it and make it a file server. Also, you can squeeze a little more performance outta your hardware by running Windows 2000 rather than XP or Vista. 2k has less background junk eating up your cpu resources, and would likely perform more smoothly on the older hardware.
Oct 01, 2009 | Gateway 300 X PC Desktop
Cpu frequency
1 gig is possible to run, but it is not possible to work your 3ghz cpu because p4s533mx can only accept almost 2.0ghz
Jan 13, 2009 | ASUS P4S533-MX Motherboard
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
4 x1gb sticks of kingston hyper x 400 mhzi but only getting 200
Hi There,
As the memory is ddr2 ram 200mhz is correct in cpuid, 200mhz x2 (ddr2) = 400mhz, The only thing I can guess at why it is not showing all the ram is do you have a graphics card that can use system memory to boost its own? This can be disabled in the bios
Dec 18, 2008 | ASUS A8R32-MVP Deluxe Motherboard
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
