Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
I have a maytag washer (model LAT9416AAE). The timer motor doesn't run. If I plug it's wires directly into an outlet, it runs fine. In the timer assembly, it apparently gets no power. Is there another place the power is switched before it gets to the timer motor, or do i need a new timer/switch assembly? THANKS! jeff kern
  • jeffkern Jan 08, 2009
    Thanks for you help. Could you explain what is wrong? The assembly looks fine (except there's one fin missing). The missing fin looks intentional. There's no corrosion or malformation otherwise.
    And why do I need to be careful with the wiring? There is a pre-assembled plug that attaches to the timer. Am I missing something?
    Thanks again, I do appreciate the attention to my problem. I'm just reluctant to spend $88 on the silly timer. jeff
  • Anonymous Mar 26, 2014
    TIMER IS NOT WORKING AND HENCE THE MOTOR IS RUNNING IN ONLY ONE DIRECTION
  • 594 Answers
You need a new timer assembly. Please be very care full when hard wiring your machine. it could short the machine out and also cause personal and property injury.
Posted on Jan 08, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag stacked washer dryer lse7806ace
Take the belt off the transmission pulley and see if you can turn it by hand. It will agitate on direction and spin when you turn it the other direction.
Put the timer to spin with the belt off and see if the motor will run. There may be a problem in the start switch on the motor letting it start in one direction but not in the reverse direction.
Special tools are required to remove the transmission and brake assembelies. You also want to make sure there is nothing sticking through the holes in the basket causing it to lock up such as a nail or screw that may have been left in a pocket.
Post back with what you find.
Thanks/Mike
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
My maytag centennial washer won't start, no lights come on. I checked the outlet it is plugged into and it's good. Anything on the washer I can try?
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
May 11, 2015 | Maytag Washing Machines
I have (7) 20W bulbs on a newly wired line running on a brand new 200W Malibu transformer, worked fine for 2 days and now it's tripping the reset button - Any suggestions ??
1) Copy following link for malibu power pack tips for longer transformer life:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Two plug choices on each outlet, Plug power pack into other outlet on receptacle.
Inspect for damage on outdoor outlet.
Replace outdoor outlet, and do not use quick connects. Connect wire directly to screws on side of device.
Replace GFCI outlet.
Feb 01, 2013 | Malibu Intermatic Inc. ML121RT Low...
I have a Maytag dependable care quiet pack 2 speed super capacity 9 cycle Model No. LAT9416AAE
It is possible that you need a new timer which is a part number: 22003362 and is usually about $75-$100 but it is also possible that one of the components of the knob is not functioning properly. The best bet is to take the knob apart (make sure the arrow points to a wash cycle first) and then pull up on the time timer shaft itself. If the washer starts then you know its one of the components of the knob that when bad. If it doesn't then you know you need a timer.
Nov 16, 2012 | Maytag Dependable Care LAT9706
My washer has filled up with water and then just stopped and wont begin the cycle...
Try manually advancing timer . If washer starts , timer motor is bad or gets stuck , or water level switch is bad and not sending power to timer.
If washer doesn't start ,the lid switch is stuck not sending power to timer or god forbid, timer is shot.
In some models , lid switch controls everything which may be your problem .Try manually operating lid switch or jumping it with jumper wire.Or just replacing. Its' the easiest to fix and most likely problem.
Good luck
Aug 15, 2011 | Maytag PAV2300 Top Load Washer
My Maytag washer Model:LAT6800AA won't run after it fill cycle. I replace the fill level pressure switch because mit would not stop filling no matter what setting the fill switch was in, now it fills...
Is your model number correct? Or is this the LAT8600AA? (typo?)
This wiring diagram is typical of most every LAT model as far as the water fill & agitation circuits:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28437491&pkw_=basket&model_id=26594&NewWindow=1
Can you select spin and have the maching spin?
Here is how to test the motor:
You can sacrifice an extension cord to build this test harness.
The direct connections for a motor run test involves making a test cord. The test cord will have 4 connections (2Y connections) I.e. each of the power / cord wires is split off to 2 terminal on each wire. This will run the motor. Reversing the motor is done by switching wires B and C
If the motor runs during this test. it is sure looking like the timer is bad.
If you can not see the end of the D wire it Connects where the BLACK wire was.
All wiring harness wires from the machine have to be removed for the test. Draw your own diagram for the wires you removed!!!!!!
Kelly
Jul 29, 2011 | Washing Machines
Drum isn't spinning but motor is
check inner tub fastens, if they check ok, replace the transmission. note: you will need special tools to change this, if you have them great, if not, you would be better off calling a&e factory service for the repair, 18009059505.
Jun 25, 2009 | Washing Machines
Washer and dryer won't run the washer will only fill
Hope this may help;
DON'T FORGET TO RATE:
Regards,
VOTIT
Sep 06, 2008 | Maytag LSE7806A Top Load Stacked...
Timer runs, but dryer will not start
Onry, the last 3 letters of the model number is missing. If this is an electric dryer the thermal fuse may be open. On electric dryers if the fuse is open the motor won't run. On gas, the motor will run but will not heat. There are two thermal fuses on the electric model. One on the front of the blower housing and the other on the element enclosure. Check the one on the blower housing first. You will need to remove the door by removing the 4 screws that hold the door hinge and spacers on the other side. Lift up on the door and pull out. Now the front panel will pull out and the blower cover will be visable. If this is a gas dryer we'll have to look elsewhere. Catriver..post back
Jan 04, 2007 | Maytag MDE2600 Electric Dryer
Washing Machines Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
