Question about Dryers
First my dryer is over heating and then its turning my white clothes grey
  • 706 Answers
Hello michelew2131,
My assumption is that your whites are turning grey because of the overtemp condition. Please correct me if I am wrong. How did you determine your dryer was over-heating? There are over-temp sensors that would/should disable the heater in that case.. I would be more inclined to believe you have a problem with your venting system or blower ( restricting air flow and cooking your laundry)
I would be interested in following up on this ( its my hobby) but it would be useful to have the brand and model aswell as type ( gas or electric) to assist in the diagnostics for you..
Posted on Jan 09, 2009
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
Friend gifted working dryer. the black cord did not match my outlet. Changed to grey dryer cord. Five wires coming from inside dryer yellow red two blue and one white. I have the red and yellow to...
The blue wires defiantly go on the outside...their are so many dryers i can not remember all details of each one off hand reply with the model number and i will check the wiring diagram and see exactly which wire goes where but even without referring to a diagram i know the blue wires go on the outside
Sep 14, 2011 | Dryers
Makes a noise like there is loose change in the dryer. Grey marks are coming off onto the clothes. checked. there is nothing inside the dryer or in the pockets of the clothes. Still happens- even with...
This sounds like a faulty drum bearing. The grey marks you are seeing are grease from the bearing. The loose change sound is from the remnants of the bearing rotating as the drum turns.
Mar 09, 2010 | Dryers
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer turns white clothes gray.
Replace Burner.
I have the same problem, getting ready to try and tackle this. I've been told it is the burner that is the problem, a crack or cracks in the burner are letting the soot into the drum instead of venting to the outside.
Dec 29, 2008 | Dryers
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Nov 18, 2008 | Whirlpool Dryers
Hotpoint dryer
two pipes on the back (white + grey about 8mm dia) dissconect and blow down them both. May be blocked.
Jan 24, 2008 | Dryers
GE DBL333EAOWW dryer
yes ...order it... you re better off changing the 2 paire of slices on the front when your take off the front from the drum ...its grey or green or white ...they must be finish ...beware they're expensive ....
Nov 28, 2007 | GE DCSR483EA Electric Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
