1993 Saturn SC2 Logo
Posted on Jan 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
93'Saturn engine problem:
Motor starts right up. Runs Great. The problem is: When it's running in warm up mode,If I put it in gear it will stall out. Then hard to start, After warm up runs great will start up every time. But, when motor cold it will stall out till the gauge reaches just past the first mark on the temp gauge.It stalls when it is cold (motor). What can I do to remedy this problem ? Bob
Anonymous
Level 2:
Sergeant:
  • Expert 319 Answers
  • Posted on Feb 02, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
319
Questions
Helped
122308
Points
704
Neuar06 is correct, the temp sensor is cracked. Mine crack was so small I could not see it. But when tested it was the problem. Technitian told me once it warms up is usually when you get the problems. but could be when its cold also.
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Jan 17, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
9240
Points
34
Engine coolant temp sensor is most likely cracked.. I know it sounds strange but pull it if your looking at the engine it is on the right side of the head Will make the car hard to start, smoke, and the idle will often race up and down.. easy to fix 15 dollars or so..
3answers
My 93 oldsmobile cutlass ciera stalls too much
Check the oil. Quite a few cars do that when they are low.
2helpful
I have a 88 grand am Se 2.0 OHC turbo, automatic the turbo does not work. my problem is that it runs great for about 1/2 hour driving until it gets warmed up. I come to a light it starts to surge and...
The TCC solenoid in the transmission needs to be replaced. It is under the side cover. It controls the converter to lock up for better fuel mileage. If you want to drive car until you get it fixed you can un-plug the connector going to the transmission on the front of transmission. This will keep it from going to lock up mode and keep it from stalling until you can fix it. Common problem.
2answers
Where is the ecm location on a 1993 suburban? I am assuming this is my problem with the truck. I have replaced distributor,coil, fuel pump and filter with no change. Truck runs great till normal operating...
I don't think it's your ECM. Your problem has a pattern which is based on time or temperature. You might try looking at the IAC or "idle air control". It regulates air intake and adjust idle speed. They can get dirty and need cleaning.
Problems accelerating
the engine tickover is too slow when the engine is cold its running on cold start, ie:choke,, after it warms up the engine slows down this is what is causing it to stall in gear,, get some one to hold the brakes hard on and with the engine running in gear ajust the tick over till its reving at 750 - 850 rpm the revs will go up a bit when its out of gear,, before you pick a gear to go into push the foot brake down to stop the car lurching,,,
93 Lincoln Conti. Runs rough in gear
Probably a bad idle air motor, it controls idle electronicaly
1helpful
Wont idel when warmed up
seems to me there may be a problem with the transmission, because you say it runs fine in neutral and dies when you put it in gear!!!
only logical thing if everything else you mentioned has been ruled out!!!
Car hesitates/stalls when engine is warm and car starts to move.
Sounds like a bad motor mount, pop the hood and see if the motor shakes or moves rapidly when u put it in gear holding down the brake.
1helpful
93 olds achieva 3.3 6cyl
sounds like ur torque convertor not unlocking u can unplug the wiring on the transmission for the convertor or pay alot money for having convertor replace cause u got pull the transmission to do it
4helpful
2answers
I have a 1994 Dodge Dakota, no power at low rpms
yes it does if it is reading lets say lower than normal that would explain easy start up and stalling later.the coolant temp sensor has two wires .so if your car warms up and your coolant is about 200 degrees your coolant sensor might say 80 degrees .access to a scanner to check temp would be great.
1helpful
2000 durango 5.2 cold starts, engine stalls or rpm surging
i know this may sound stupid but if your battery is old or a little weak on this vehicle the idle air control solenoid will act speradicley hunting for were it should be and the vehicle will stall.replace battery
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
