Question about T-Mobile MDA
Bluetooth help i have a t mobile mda , bluetooth is working fine , but i m not able to recive any file from other mobile , error mesgae says that service not supported ,
  • 3 Answers
U need to enable first the ir/beam buttom in the comm manager, then enable the bluetooth and ready
Posted on Aug 06, 2007
SOURCE:
When i try to save music file which has been received from bluetooth device the error is getting General System error. Please do need full regarding this
you don't have any problem in your mobile phone it's a simply problem as all the nokia phone as this same problem as you no that the nokia mobile contain two memory primary memory and secondary memory. If you recive any thing from bluetooth means it will be get stored to the primary memory all the time so you better delete the recived files in the message box means you will get solved your problem .
Jun 10, 2011 | Nokia 5230 Cell Phone
Bluetooth not reciveing
no memory enough.no solution.buy original NOKIA
Feb 16, 2010 | Nokia N95 Cellular Phone
No bluetooth hardware on t-mobile mda
dear u need to reinstall ur OS on ur MDA it will automatically install ur blue tooth device drive..there is no possiblity that in MDA blue tooth wont present...so go to start>> setting >> clear Storage...and then wait for ur OS to install automatically...but remove ur storage card and also backup of ur data (device data) or copy it to storage card...it will work..
Feb 17, 2009 | T-Mobile MDA
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on iwannatoken@hotmail.co.uk il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
Aug 31, 2008 | T-Mobile MDA
No network service
First try using other sim card and if the network is active if not then you need to reinstall the phone software as its corrupted if the phone is within warranty get it done by the phone company or if its out of warranty get it done by local mobile service center, IF the phone network is active with order sim card then you to contact the service provider and get the sim unlocked ..
Good luck...
Aug 27, 2008 | MDA Game Controller: Bluetooth Game Pad...
Tmobile mda
Turn the bluetooth off to the phone it could be its always trying to send to bluetooth. If not your speakers are gone.
Mar 01, 2008 | T-Mobile MDA
Saving Text Messages
Your best bet is to get a hook up to a computer and transfer files that way. If you have a newer laptop you can use bluetooth or get a bluetooth adapter.
Feb 15, 2008 | T-Mobile MDA
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
Windows media player
hi, my MDA T Mobile memory is full so i deletes some file, but after then i can't open my VIDEO & PICTURE VIEWER, can you help me solve my problem ? Thanks before
Dec 16, 2007 | T-Mobile MDA II
Dropped oil in T-mobile MDA
open up the mda with torque 6 screwdrivers and use a q tip to clean it up inside.
Sep 16, 2007 | T-Mobile MDA
T-Mobile MDA Logo
100 people viewed this question
Top T-Mobile Computers & Internet Experts
Marvin
Marvin
markpain
Level 1 Expert
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
